#267 |
Drives: gt86
Can these be installed using oem top mounts? (I could not find if this was asked before)
#268 |
Drives: 2014 GT86
I somewhat doubt it. And even if one can, wonder where to get tein-spring specific upper perches to be used with OEM top mounts.
They have their own camberplates in set though, and you should have all needed for mounting included. |
#270 |
Drives: gt86
#271 |
Drives: 2014 GT86
Well, not with all shocks/camberplates combos there are noticeable NVH issues to care much about. While NVH was not to my liking with stock shocks+camberplates, imho these teins properly installed should do fine.
#273 |
Drives: Frs
did anyone else have a really tough time adjusting the ride height (bottommost collar) on the rears when they were brand new?
Mine wont budge. I put a wrench on it, and then used the other wrench on the topmost collar (with it locked against the middle collar). my friend and i stepped on both and it wouldnt move i put them on the car just so i could drive again. When i try to adjust it on the car, the collar moves the threads and the top two collars also move, basically spinning the whole strut in place. In other words, I cant get the bottom most collar to move up the threads and away from the green cup. Am I missing something? Youre supposed to loosing the bottom most collar (to the right, up the thread body), then twist the bottom green cup to eat up more of the threads to lower the car right? Or if its already mounted, used the top collar to twist the threaded body into the bottom green cup which you hold stationary? That seems impossible for me its as if the bottom collar is bonded to the threads am i missing something? edit: friend of mine said hit it with a hammer and flathead Last edited by Lav; 06-28-2020 at 03:01 PM. |
#274 | |
Drives: 2022 GR86
This video also explains why some higher-end coilovers don't have the body length adjustments altogether: A good starting point for all dimensions for these TEINs is provided in the manual that came with them. |
#275 | |
Drives: Frs
If i lower the preload collar (to shorten the distance between the ride height collar and the locking collar) wont I just be lengthening the spring? Making no difference on ride height? Im still stuck trying to move the ride height collar. Tried PB, flathead + hammer, spanner + hammer, spanner + ratchet for leverage. If anyone has any insight please help |
#276 | ||
Drives: 2022 GR86
[in my own words] The term "preload" only makes sense in the context of a fully extended coilover, it defines how much external force you need to apply to start compressing the spring as part of the suspension. Any reasonable amount of preload is much less than the forces applied when the weight of the car is applied to the suspension. Once the weight is applied, the position of the top collar 100% affects the ride height, effectively acting as an offset. Quote:
Anyhow, I would suggest you avoid applying too much force until you hear back from CSG / TEIN. |
#277 |
Drives: Frs
bro that makes so much sense Sent from my ASUS_I01WDX using Tapatalk |
| The Following User Says Thank You to Lav For This Useful Post: | Jdmjunkie (06-29-2020) |
#278 |
Drives: Frs
for posterity (though it appears no one else struggled like i did)
stuck ride height adjustment collar won't move brand new pb blaster + flathead screwdriver + flathead for the rears worked for me. Breaker bar made me nervous how much the whole housing would flex and turn so i went for sudden impacts. I had to swing pretty damn hard. Once it broke loose it spun freely wd 40 (just kuz that can was closer to the front), spanner wrench + breaker bat for the fronts it was a lot harder than i expected, and a lot harder than any videos made it out to be even though mine were right out of the box. Sent from my ASUS_I01WDX using Tapatalk |
#279 | |
Drives: Subaru BRZ / Toyota 86 Experts
| The Following User Says Thank You to CounterSpace Garage For This Useful Post: | Lav (06-30-2020) |
#280 |
Drives: 2017 Subaru BRZ PP
I recently installed a wisefab rear on my BRZ. With the drop spindle, my Flex A doesn't adjust high enough to get to my desired ride height. I want to order a taller rear spring to correct it.
I don't know what dimension of a spring to order. What is the height and inner diameter of the included factory spring? I was thinking of getting a 2 inch taller spring than stock as currently it has an absolute ass load of preload and adjusted as high as possible while still leaving enough threads engaged, just to get to neutral rake. Will a 2 inch spring translate to a 2 inch higher ride height in the rear? I've also been floating the idea of bumping up the rear spring rate by 1kg/mm. Would this have a major impact on balance? I feel like the car could use some help rotating at lower speeds. If it will be a very minor difference in balance and won't negativity impact the effectiveness of the dampers then I would be willing to give it a shot. The other option I have is getting a stiffer rear sway bar, but I'm not sure about how much stiffer it would get than stock. Do they sell rear sway bars that can adjust in the range of less than 1kg/mm to more than? |
| WTB Tein Flex Z | HachiRo | Want-To-Buy Requests | 1 | 09-19-2016 02:13 PM |
| tein flex z | mclovin85 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-14-2016 07:27 PM |
| TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day | CounterSpace Garage | Groupbuys | 47 | 02-18-2016 01:33 AM |
| Help wanted: Tein Street Flex for $950 or Flex Z or $820? | chezzy79 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-01-2015 10:33 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 02:10 PM |
