#197 |
Drives: Hot Lava FR-S
Is there any markings and or ways to tell if a set of tfa are truly CSG? There are some used ones in my area and I dont want to buy just flex a's.
#198 |
Drives: 2014 GT86
As dampers are kind of wearables too .. maybe it's more worth to save for new set? As for those used ones .. CSG started making/selling custom valved As not that long ago, and most customers liked them, so imho there might be little chance for them to soon selling them off for something else, and thus little chance for those to be of CSG spec.
#199 |
Drives: Subaru BRZ / Toyota 86 Experts
It says "CounterSpace Garage" on the tag. There are maybe 1-2 standard FLA units that have been revalved and serviced to CSG Spec, but they are very specific individuals who wanted to pay for the service. FYI, it's far more budget conscious to just order the CSG FLA instead of converting a used FLA to CSG Spec.
#200 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | timurrrr (09-05-2019) |
#201 | |
| The Following User Says Thank You to TaylorFRS For This Useful Post: | CSG Mike (09-05-2019) |
#202 | |
#203 |
Drives: LS Swapped Scion FRS = 440HP
Did my first road course on these coil overs, they handled well, but with the front camber maxed out at the strut towers (I think they were 2.4 degrees), I managed to wear the outer edges of my hoosiers down to the belts in four sessions. I'd like to go closer to 3.2 to 3.5 degrees... is the only reasonable way to accomplish this with an adjustable lower control arm? I assume camber bolts on coilovers would be frowned upon at this point. ?? Video for fun. You can hear my winmax w4 pads screaming in agony. [ame]https://www.youtube.com/watch?v=7jmU4bEsK9g[/ame]
#204 | |
Drives: 2022 GR86
| The Following User Says Thank You to timurrrr For This Useful Post: | CounterSpace Garage (09-10-2019) |
#205 |
Do the cam bolts, no issue if properly installed
#206 | |
You can use crash bolts to gain additional camber up front. It should be easy to get -3 to -3.5 with that setup and our camber plates.
Also, if you're working the course like that, you're going to need a proper pad. Understandably you have a retrofit CTS-V kit, but heat is still going to be an issue and a pad compound is required to take on that heat on top of the stress from using Hoosiers. Let us know when you can provide us additional feedback. We'd love to help optimize your setup so you can run harder. ![]() Quote:
#207 | |
Have a picture of the top hats? You may need to move the bolts over a hole or two, to get more clearance! |
| The Following User Says Thank You to CSG Mike For This Useful Post: | timurrrr (09-10-2019) |
#208 | ||
I was just informed I won best engineered car. Too bad I didnt stay for the award ceremony. Brakes held ok through the 20 minute sessions. I only noticed one time where I thought they were fading. Being my first road course in this car, (and first time on NCM) I wasnt pushing as hard as I could have. I definitely like my winmax W3's/W4's for autocrossing, but wouldnt mind stepping it up a bit for the next track day (within reasonable budgets) The car is likely going to Toronto Motorsports Park perhaps next month to get reviewed on Speed Academy for quick three hot laps. ![]() ![]() Quote:
#209 |
#210 | |
TMP is pretty hard on brakes and having Hoosiers certainly doesn't make that task easier. Let us know if you need something that will actually hold up to that task. With a seasoned veteran driver, the car is going to see some incredible pace. Like we discussed in the past, we got the pads to take on the task and won't cook your caliper. There are certainly pads that are more budget oriented, but you will need to monitor the caliper temperature and fluid.
PM us if you want us to get you setup for next month! We've rushed some parts over to some clients who will be working with Speed Academy soon. ![]() Quote:
| WTB Tein Flex Z | HachiRo | Want-To-Buy Requests | 1 | 09-19-2016 02:13 PM |
| tein flex z | mclovin85 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-14-2016 07:27 PM |
| TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day | CounterSpace Garage | Groupbuys | 47 | 02-18-2016 01:33 AM |
| Help wanted: Tein Street Flex for $950 or Flex Z or $820? | chezzy79 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-01-2015 10:33 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 02:10 PM |
