#141 | |
Drives: Subaru BRZ / Toyota 86 Experts
#142 |
Drives: LS Swapped Scion FRS = 440HP
Just arrived 5 minutes ago!
I know what I'm doing tonight...
| The Following User Says Thank You to spitsnaugle For This Useful Post: | CounterSpace Garage (02-13-2019) |
#143 | |
Drives: 2017 BRZ w/PP
one odd thing i didnt see in there was recommended camber. im thinking of 2 square since i DD my car too |
| The Following User Says Thank You to Breadman For This Useful Post: | CounterSpace Garage (02-13-2019) |
#144 |
Generally speaking, the recommended alignment is specific to each individual. We slammed and lifted the kit + tossed in a plethora of variables for settings. At the end of the day, we're probably racers are heart so we want to stick to our performance setup.
Depending on DD settings, you'll want a little less camber if you're just running strictly street miles. |
#145 |
so ive been driving on mine for 3 days more or less and will say the difference between stock pp and theres are night and day. i went with the recommended drop and 8/11 clicks and on smooth roads they hook so well. i did eventually go 4 clicks softer all around because when i got to bad roads with ruts it would track the rut really badly, and when i hit big potholes i could feel my back lift. im sure a -1/16th or -1/8th toe in the back will help keep the back a bit more stable.
right now im eyeballed -2.5 front -2 back but will get a real alignment friday. ill probably go a bit stiffer once i get use to them/have a real alignment. cant wait to put my conti summers on and autocross this |
#146 | |
Drives: 2017 Toyota 86
#147 |
#148 |
I've been tinkering with my camber over the past couple days, I'm just curious, do the hash marks on the camber plates relate to a certain degree of camber? I've just been measuring at the wheel but not paying attention to the marks.
On Camber thoughts- I'm around 3˚ front and 2.5˚ rear right now, whats the chances of needing toe arms? (I'll probably go to 3.25 and 2.75 eventually, slowly making adjustments here and there) |
#149 | |
Drives: Car
No, you won't need toe arms unless you're running something crazy. I've had more camber than you and the stock toe arms were more than enough. |
#150 |
I guess while I'm here, is this amount of leftover welding slag/splatter normal?
Not a terribly big deal, but I wouldn't want anything to cause premature corrosion...
#151 |
Drives: Car
#152 |
Drives: 2013 Scion FRS
Finally got em!
#154 |
Some updates for latest incoming batch - ETA is end of March/beginning of April.
Recommended adjustments are in the manual. This will give you a fairly nominal setup and you can adjust from there.
| WTB Tein Flex Z | HachiRo | Want-To-Buy Requests | 1 | 09-19-2016 02:13 PM |
| tein flex z | mclovin85 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-14-2016 07:27 PM |
| TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day | CounterSpace Garage | Groupbuys | 47 | 02-18-2016 01:33 AM |
| Help wanted: Tein Street Flex for $950 or Flex Z or $820? | chezzy79 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-01-2015 10:33 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 02:10 PM |
