Old 07-11-2013, 02:42 PM   #757
swift996
swift996's Avatar
I had an opportunity to ride in a BRZ equipped with the AP racing sprint kit and wow
I had some weak street pads on my Wilwoods but the AP system had significantly more stopping force. Part of it could have been the passenger seat but I was very impressed. I'm swapping out my pads this weekend and will get another track day here in a few weeks which will give me a better apples to apples comparison.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-11-2013, 02:52 PM   #758
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Show up to ITR Expo and we can compare. I know you can't for other reasons though
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-11-2013, 03:48 PM   #759
swift996
swift996's Avatar
I wish I could. Although Mid-Ohio isn't too tough on the brakes (if they leave the chicane in). Plus I'll have my innovate supercharger on tomorrow night
At some point you need to visit my home course, our cars were made for it:
Old 07-11-2013, 03:57 PM   #760
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I was at Slummit a few weeks ago.
I will never run an event there due to history with them from 2004 (yeah I hold grudges when it almost destroys my event) but I don't mind visiting.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-11-2013, 03:59 PM   #761
swift996
swift996's Avatar
I'm hoping to get to VIR in august. I need to order an oil cooler ASAP.
Old 07-11-2013, 05:29 PM   #762
ja1217
Drives: 2004 Toyota RAV-4 5M
What organization are you running with? I'll be at VIR with TrackDaze Aug. 26 - 27 and again in Nov 11 - 12.
@Dave-ROR
Just curious, but what happened at Summit? I was there last weekend and had a good time.
ja1217 is offline   Reply With Quote
Old 07-11-2013, 05:48 PM   #763
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Or build one.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-11-2013, 05:51 PM   #764
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
@Dave-ROR
We were planning our annual event there (ITR Expo) and they were beyond difficult to deal with and eventually pulled the date because they screwed up on Shen when they were building it. Instead of having us run one of the other courses, they were just complete jackasses. All good though, they lost the money, BeaveRun took us back with very little notice and we sold out quickly so it all ended well.. but it could have been bad. I avoid dealing with tracks that I've had issues with in the past (I mean running/organizing events there, not going to events at said location) simply because I don't have the free time and energy to expend on unresponsive people who I am paying 5 figures to for a service.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-11-2013, 06:09 PM   #765
swift996
swift996's Avatar
That was one I was looking at. (August)
Old 07-12-2013, 11:23 AM   #766
ja1217
Sweet, I'll see you there.
Back to my earlier post, is just removing the pad retention bolt all you are supposed to do to swap pads? Like I said, it can be difficult to get the pads in and out, especially when there is still a lot of pad material.
Old 07-12-2013, 11:53 AM   #767
Hanakuso
Back to my earlier post, is just removing the pad retention bolt all you are supposed to do to swap pads? Like I said, it can be difficult to get the pads in and out, especially when there is still a lot of pad matetial.
These are helpful
Leave one pad in when you do that BTW, otherwise you'll move the other pistons too which just makes more work when you do the other side. I usually remove the outside pad first, then open the bleeder, then push those pistons back in with two old pads (pads sitting horizontal, one per piston for leverage). Then install replacement pad. Then move to the inside, compress pistons again, close bleeder, install replacement pad.
You can just use a screwdriver between the rotor and pad that's already there as well but I don't use that method.
Originally Posted by JRitt View Post
Guys,
When you're pushing pads back in...be careful! If you do use the brake pad turned 90 degrees method to span both pistons, wrap the pad in a shop towel. Otherwise the edge of the disc against which you are levering can damage the pad. Also, the edges of the pads and gouge or damage the pistons...which is not good. Also, you have to be careful doing this with race pads. Some become brittle after a number of heat cycles. If you use them as a lever, drop them on the ground, etc. you can easily crack the pad material.
You may just want to fashion a small, smooth block of wood for this purpose. It will be easier on your pistons, your discs, etc., and you won't have to worry about breaking, scraping, or gouging anything. I had a little pine block that I used for years. There are a couple of caliper spreaders on the market (the Girodisc one comes to mind), but they are expensive and large/difficult to store and transport.
As Dave said...do one side at a time, or you'll be playing piston tennis....back and forth, and back and forth.
I'm getting tons of PM's...if you guys have any questions about what's right for you, call me 704-824-six zero three zero 8-5pm ET. I don't bite, and it's far easier and faster than sending 46 messages back and forth as I gather details!
Hanakuso is offline   Reply With Quote
Old 07-12-2013, 01:17 PM   #768
ja1217
Originally Posted by Hanakuso View Post
These are helpful
Thanks, I must have missed those posts in the 35 pages in this thread
Old 07-12-2013, 01:48 PM   #769
nix
nix's Avatar
Drives: AVO BRZ
Fwiw the ds2500 are silent on my oem caliper/rotor even with a light bed in.
I'm still eyeing a sprint system but want matching rotors >_>
nix is offline   Reply With Quote
Old 07-15-2013, 01:58 PM   #770
The stuff works
The Following 8 Users Say Thank You to CSG Mike For This Useful Post:
ATL BRZ (07-15-2013), Captain Snooze (07-15-2013), Dimman (08-03-2013), Hanakuso (07-15-2013), ICantAffordAnLFA (07-15-2013), JRitt (07-18-2013), Shinryu (07-15-2013), Simpleviet (07-15-2013)
Search this Thread:
Advanced Search
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 11:34 AM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 03:36 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
