#561 | |
Drives: Brz, Legacy
Had a quick look at these and I'm not sure they'd fit even under my 18s
Trackday ride with built motor
Mods: Going, Stopping, Handling Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX |
#562 | |
Drives: 2012 BRZ Premium WRB 6MT
Details are up on our blog page.
Ro_Ja...this one's for you kid.
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing www.essexparts.com ![]() |
#563 |
Because compromise ®
Drives: Red Herring
@JRitt
Will there be an overhaul/service kit for the competition systems? I don't fancy sending calipers 1/2 way around the world to get serviced. ta |
#564 | |
From our site: Essex is AP Racing's official North American caliper reconditioning center. We have skilled service technicians rebuilding hundreds of AP Racing calipers each year for the top teams in NASCAR Sprint Cup, ALMS, etc. Hardness testing: After disassembly your calipers will be Rockwell hardness tested against the standard for that particular caliper type as sold new. This test provides a relative understanding of how much fatigue and stiffness loss your calipers have experienced. Tired calipers lead to pad tapering, increased pad wear, leaky seals, and a loss of pedal firmness, all things you want to avoid. Essex will make a replace or rebuild recommendation based on the results of this test. Ultrasonic cleaning: After passing the hardness test, your calipers will be placed in an ultrasonic cleaner to remove all dirt, debris, brake fluid, etc. This method produces results that are far superior to what the average racer could accomplish via hand-cleaning. Inspection and re-assembly: All serviceable parts of the caliper will be inspected and replaced if necessary, including the seals, abutment plates, pistons, and bleed screws. Cyclical Pressure Testing: After your calipers have been rebuilt, they will be cycled at high and low pressure on a pressure bench to ensure proper functioning. This is important, as certain leaks only show up under specific pressure conditions. Price: The labor price to rebuild a CP8350 is $78 per caliper. That does not include parts. Assuming there has been no damage to the caliper, Essex typically recommends replacing the seals ($40) and bleed screws ($15) during the standard reconditioning process. For roughly $125, you can have a fresh, professionally serviced caliper in peak operating condition.
| The Following User Says Thank You to JRitt For This Useful Post: | Captain Snooze (01-24-2013) |
#565 |
Drives: Brz, Legacy
What spacer is reqd to get stock alloys over the endurance kit.
My car will sit on the stock wheels between trackdays; no real mileage on them though
#566 |
Site Moderator
Drives: Stuff
No idea.. 10mm allows them to clear the sprint. The design of the OEM spokes make me think it'll require even more. At 10mm+ you need extended studs IMO, or spacers with the studs built in.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | ICantAffordAnLFA (01-24-2013) |
#567 |
Drives: Brz, Legacy
might just by some used cheapo 18s instead
#568 |
#569 |
Drives: BRZ WRB
Just in case, maybe someone also has this question, as only hyper-racers live in this thread
WHEN would one want to switch to harder wheel studs than OEM? I have Endurance kit and plan beat the shit out of it, so the wheel (studs ) would get hard time on the track. Should I upgrade to, say, ARP from OEM if dont need LONGER studs? |
#570 | |
Site Moderator
Drives: Stuff
A few guys here have broken OEM studs already. I mostly replaced mine for the lazy installation benefits. I'm a fan of ARP studs.
-Dave
#571 |
Drives: Some rust bucket
Don't most people who want a BBK already have aftermarket wheels?
#572 |
#573 |
Site Moderator
Drives: Stuff
Probably but they may want to use stock wheels on the street (or track, or winter, or as spares, etc).
-Dave
#574 |
Drives: Brz, Legacy
So I guess you guys that have these kits on, are just changing the pads out for your road miles?
How material is the lack of boot in the piston corrosion / road salt argument? Not planning on driving in high salt conditions but there is always the risk it will be around.
| BC Racing Coilovers with Free Stainless Steel Brake Lines!!! | Dustin@Dynosty | Brakes, Suspension, Chassis | 21 | 01-08-2013 11:34 AM |
| SS Racing Brake Line | K1 Motor Works | Brakes, Suspension, Chassis | 5 | 06-29-2012 03:36 AM |
| Essex/AP Racing Competition Brake System in Development | JRitt | Brakes, Suspension, Chassis | 1 | 06-14-2012 02:32 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 11:28 AM |
