#547 | |
#548 |
Wise old man
Drives: 86 GTS
sounds like pad deposits.
#549 |
#550 |
#551 |
Drives: BRZ WRB
just FYI - my choice on pads for the Essex Endurance kit
I went with Ferodo DS2500 allaraound for the street use (huggy & acceptably silent), and will be swapping the fronts for AP C300 for the events, leaving rears with DS2500's Jeff assured me this combo would work great in both cases Cheers! |
| The Following User Says Thank You to MSTiFK8R For This Useful Post: | Anthonytpt (01-24-2013) |
#552 |
Drives: 2012 BRZ Premium WRB 6MT
Grooved discs
A little bit of grooving on any disc with race pads is nearly inevitable. I don't think I've ever tracked a car without having some sort of minor grooves appear on a disc. When I worked at StopTech and had their brakes on my C5 Z06, the discs looked like Pringles! That said, I never had any problems as a result. As Dave was alluding to, if you're tracking your care frequently, you're going to crack your discs long before you run them thin...period. So nothing to worry about there. Hanakuso, Your discs are not warped. And yes, the hat is seated properly on the disc. Please don't waste your time searching for a "problem" because of a little squealing. That's just pad interaction on the disc face. When you run ANY pad hot on a disc, it's going to leave a film of pad on the disc called a transfer layer. All pads are different, and how much and how thick the transfer layer is will be different...and how that pad reacts with other pads is going to always be different. When swapping from street to track pads, you have to manage the process. Have you ever seen this video I did? There's another one on there about bedding pads as well. If you guys start running into massive judder/vibration (you hit the brakes and the brake pedal and steering wheel go thunka-thunka-thunka), then you need to start looking at solutions...and you will know if, when that happens...and that can happen, even with the best system. You just have to know how to manage your brakes. From everything I've read/seen in these last two pages...everything is working awesome, and as intended, with our systems under heavy track use. No brake fade, no judder, soft pedal, no odd pad wear, no serious disc cracking even after quite a few events and extended hot lapping sessions. Is that a fair statement? It's obvious that some of you have been to this rodeo before, and others have not. Those of you who haven't just need to understand/and learn about what you're seeing and how brakes react to getting cycled at 1200 degrees F over, and over, and over again. I'll do my best to show you that. The videos on our website will help a bit, and I can answer other questions. Finally, if you're ever unsure about something, just call me! :happy0180: Off to a meeting...I'll check back in later to answer any other questions. Thanks.
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing www.essexparts.com ![]() |
| The Following 2 Users Say Thank You to JRitt For This Useful Post: | track_warrior (02-05-2013), WillRacer1jz (01-18-2013) |
#553 | |
There is a red 643 WHP Lancer Evo RS in San Jose California regularly running our Endurance System on the track, and they work great on that car. If that thing can't put a dent in the Endurance System's armor, an FT86 certainly won't. To answer your question directly, even the most souped up FT86, on a brutal braking track, with a top driver will not exceed the Endurance System's performance envelope. That's precisely why it is designed the way it is!
| The Following User Says Thank You to JRitt For This Useful Post: | ICantAffordAnLFA (01-17-2013) |
#554 | |
Drives: Brz, Legacy
I've 18x7.5 CE28s
Trackday ride with built motor
Mods: Going, Stopping, Handling Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX |
#555 | |
#556 |
Big news on the AP Racing road car systems gentlemen. We are officially getting the fully built AP Racing front and rear system that fits stock wheels!
I'm going to start a new thread on them and get all the details up on our blog. Thanks.:happy0180:
| The Following User Says Thank You to JRitt For This Useful Post: | Anthonytpt (01-24-2013) |
#557 |
Site Moderator
Drives: Stuff
Not for me, but nice!
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#558 |
Drives: TOYOTA
YAY!!!!
#559 |
#560 |
Drives: TOYOTA
| BC Racing Coilovers with Free Stainless Steel Brake Lines!!! | Dustin@Dynosty | Brakes, Suspension, Chassis | 21 | 01-08-2013 11:34 AM |
| SS Racing Brake Line | K1 Motor Works | Brakes, Suspension, Chassis | 5 | 06-29-2012 03:36 AM |
| Essex/AP Racing Competition Brake System in Development | JRitt | Brakes, Suspension, Chassis | 1 | 06-14-2012 02:32 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 11:28 AM |
