Old 10-31-2012, 11:13 PM   #351
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
They've replied before. That's an AP Racing system, not Essex Parts. It'll be released when AP Racing releases it, I'm not sure Essex knows any exact details since they aren't building those kits.
Interesting, the wording was bad then since it appeared they were making that kit as well. Guess I missed that post whoops.
post_break is offline   Reply With Quote
Old 11-01-2012, 01:11 AM   #352
UncleFester
Originally Posted by pcasso87 View Post
I liked the face of the 17x9 wheel a lot better. What size spacer do you think is needed to clear the sprint kit Jeff?
15mm might work, someone would have to confirm. The lack of clearance is pretty significant. (I'm the one that measured it)
UncleFester is offline   Reply With Quote
Old 11-01-2012, 01:31 AM   #353
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Enkei should look into making the PF01 in 17x9 +45
uspspro is offline   Reply With Quote
Old 11-01-2012, 01:36 AM   #354
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Thanks for being the test mule man, so what are you going to do keep them or return them?
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 11-01-2012, 04:00 PM   #355
UncleFester
Returned them. Went with the 17x8.
Old 11-01-2012, 10:11 PM   #356
Nezz
86DESU
Nezz's Avatar
Drives: 86 GTS, S13, CB9
EDIT; All information was available and I wasn't awake enough. Now to wait for my rims and see if these fit!
Nezz is offline   Reply With Quote
Old 11-02-2012, 12:23 AM   #357
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
This is from post#12 at the beginning of this thread:
"We are also working with AP Racing to spec out a few other kits, from their Formula line of products. These will use painted calipers with dust boots, etc., and will contain a few enhancements that Essex has specifically requested. We're going to have a four piston front kit that will fit the OEM 17" wheels, a six piston front, and four piston rear. These will all be fully built in England at AP's facility, and they are using some cool new caliper designs. I'll post more pics and info on these setups as we move forward. These setups will be a little more expensive than the competition systems."
At this time we don't have any further info, but I promise I will update when we do. :happy0180:
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing
www.essexparts.com
JRitt is offline   Reply With Quote
Old 11-02-2012, 11:16 AM   #358
JRitt
JRitt's Avatar
Hi Guys...back from SEMA...crazy week as always!
You can see the Sprint system on a few cars at SEMA on our blog page. Sample below. Enjoy.
www.essexparts.com
Old 11-02-2012, 12:07 PM   #359
djdnz
1337
Drives: 2013 BRZ WRB S/C
Sorry for the off topic... but I want those wheels, however I am not a millionaire unfortunately.
djdnz is offline   Reply With Quote
Old 11-02-2012, 11:45 PM   #360
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
Glad you and Bryan Berk connected, Jeff. Did you meet him at SEMA or only over the phone before the show?
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 11-05-2012, 12:01 PM   #361
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Finally had a couple of hours to spend on the BRZ yesterday. My rears still look good, plenty of rear pad left
So for the front, I installed the Essex Spring kit, also removed the hubs and swapped lugstuds to ARP extended studs. Will post pics of the old front components in a few days, rotors weren't bad minus the delamination, pads were probably at 30% left but didn't look too bad, calipers weren't leaking, dust boots turn to dust if you touch them of course.
For all those 5x114.3 people I wonder if an STI hub has the same bolt pattern? If so it might swap over although usually bearings/hubs designed for a driveshaft don't last long without them...
Pic of the front driver side:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-05-2012, 12:10 PM   #362
gmookher
dave what were your driving and bias/trail braking impressions under HARD/HOT cornering? I'm talking error correction near apex, does the tail fly out?
gmookher is offline   Reply With Quote
Old 11-05-2012, 01:46 PM   #363
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The car doesn't trail brake for shit, the stupid slip light just flashes instead and EBD tries it's best to prevent effective trail braking. Maybe running a more agressive rear pad will help, I'm only running Carbotech XP8s in the back right now. Someone else (matt? or pcasso? or CSG?) got the car to behave better for trail braking by running narrower rear tires, we do that to get rotation in the FWD race car too.
I've never had the tail fly out on this car (on the track anyways). I need to play with alignment eventually but I'll do that when I need to fine tune it.. right now it's pretty balanced and doesn't understeer or oversteer.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-05-2012, 05:25 PM   #364
Matt Andrews
Drives: race cars
How did you replace wheel studs? Did you press them out or hammer them out?
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 11:34 AM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 03:36 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
