#337 |
Site Moderator
Drives: Stuff
I probably won't be installing mine until next week sometime, waiting for extended studs to come in (hopefully arriving monday) and then some lugnuts.. forgot this damn thing is M12x1.25.. I don't have any of those open ended..
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#338 |
Vtec Jesus
Hey Dave, if I remember correctly you had the sti caliper upgrade front and back. Did you feel that you still needed more of an upgrade over that?
#339 |
Site Moderator
Drives: Stuff
I was/am using stock calipers and rotors currently.
-Dave
#340 |
Vtec Jesus
#341 |
Site Moderator
Drives: Stuff
I never went to an STI setup.
-Dave
#342 |
Vtec Jesus
#343 |
okay, tracked it hard on oe calipers...
they smoked a bit after I parked, after a cool down lap. guess they got hot. started it back up and drove it around has nothing to do with being a noob- after maxing out 2nd and 3rd gears and hitting 4rth, then going into a 110degree corner requires standing on the brakes,at the very last second, if you were lucky enough to pass anyone on the straight-way, dropping to 2nd and redline to exit that corner into the next. its a one minute track so you dont get alot of time to cool off in 20 minute runs. I ran 1'21" initially and was at 1'11" by the time I got done. For reference, the guys in the 800hp open formula cars are turning the track in 58 seconds. so far, no detrimental results, the ferrodos got smelly when it was hotter out during the afternoon, but I'm drinking the kool aid here to some extent, and its worked so far: i suspect there is much more heat generated when parts start to fail, ie, if you boiled the oe fluid, that gas build up and you pumping the brakes hard is what blows the seal, never track these cars with the crap factory fluid! also, the crappy oe rotors as they develop surface cracks and defects, this pending failure can generate TONS more heat, that worsens the likely hood of boiling fluid, creating gas, and blowing/burning a seal. Given the delicacy of the system, and failures I read here, I started with the motul 600, and went with a powerslot cryo rotor, not exactly bank breaking at $112 each, but almost twice a centric blank. the theory is if you can prevent the cracks, prevent the boiling, the systems heat 'malfunction' can be kept in check. with more track days next month, lets see how this all holds up yes, car could use a bit more brake...hello AP racing |
#344 |
Site Moderator
Drives: Stuff
Looking forward to seeing how your calipers hold up.
-Dave
#345 |
Drives: Scion FRS, Subaru BRZ, Supercharged
delete
#346 |
I'm planning on going to the track every other month, the main usage of my car is a weekend car that i'm hoping will last 100k+ miles. Will this brake kit be reliable for mostly street driving with a track day here and there? Not having dust boots will effect me in anyway on streets?
I basically want a rock solid brake system that is easy to use and good for both track and street driving. |
#347 | |
#348 | |
Track Junkie
Drives: Faster than the Stig!
I liked the face of the 17x9 wheel a lot better. What size spacer do you think is needed to clear the sprint kit Jeff?
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
#349 |
Professional Smartass
Drives: White Out FRS
I'm going to ask one last time since every other time I've been ignored. What is the status of the smaller 4 piston formula system?
#350 |
Site Moderator
Drives: Stuff
They've replied before. That's an AP Racing system, not Essex Parts. It'll be released when AP Racing releases it, I'm not sure Essex knows any exact details since they aren't building those kits.
-Dave
| BC Racing Coilovers with Free Stainless Steel Brake Lines!!! | Dustin@Dynosty | Brakes, Suspension, Chassis | 21 | 01-08-2013 11:34 AM |
| SS Racing Brake Line | K1 Motor Works | Brakes, Suspension, Chassis | 5 | 06-29-2012 03:36 AM |
| Essex/AP Racing Competition Brake System in Development | JRitt | Brakes, Suspension, Chassis | 1 | 06-14-2012 02:32 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 11:28 AM |
