Old 10-15-2012, 03:25 PM   #239
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Can you guys provide me with a template for the front Formula system? Need to check clearance.
post_break is offline   Reply With Quote
Old 10-15-2012, 03:28 PM   #240
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm not sure there is one yet? Essex has one for their Sprint and Endurance systems that they've created:
Sprint - http://www.essexparts.com/media/down...eltemplate.pdf
Endurance - http://www.essexparts.com/media/down...eltemplate.pdf
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-15-2012, 03:30 PM   #241
gmookher
wow
gmookher is offline   Reply With Quote
Old 10-15-2012, 05:56 PM   #242
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Thanks Dave...we do not have one for the Formula Systems yet, but I will post them as soon as I have them. Thanks.
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing
www.essexparts.com
JRitt is offline   Reply With Quote
Old 10-15-2012, 06:19 PM   #243
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
Dave-
Did you use new rotors or have these turned before you put on the XP10s? I know sebring is hard on brakes, but that is a little surprising. Could be because of the fluid you used. The blue fluid sucks.
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 10-15-2012, 06:29 PM   #244
post_break
post_break's Avatar
Gotcha, I only asked because the formula kit is the only one they said would fit stock wheels.
Old 10-15-2012, 06:34 PM   #245
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Matt Andrews View Post
Dave-
No, it's preferred but I rarely do and have never had issues in the past 12 years of not doing so.
Sebring full is actually pretty easy on brakes, Sebring club course is HELL. We did 14 hours racing on Sebring Full and brakes lasted all around on the race car (not a BRZ/FRS obviously, but standard OEM honda brakes on an Integra with ST43 pads).
I am switching from ATE fluid, but this is the first time I've boiled it.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-15-2012, 06:35 PM   #246
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yeah I need to figure out what size spacers will be required for OEM wheels over the Sprint setup. That may have been posted in this thread already.. I'm going to put extended studs in while I'm at it... speaking of that I need to call Titan in Orlando to order those.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-15-2012, 07:45 PM   #247
Matt Andrews
Drives: race cars
This is your problem. The carbotechs aren't like the porterfields. They are ceramic, and if you don't use new rotors or turn the ones you have, they won't transfer any material to the rotors. I have swapped other pads back and forth, but you can't go from a standard pad to a ceramic. The transfer process and bedding process for the carbotechs is really important.
http://www.ctbrakes.com/faqs.asp#bedding2
They'll be different brakes if you turn your rotors and bed them properly - I promise. I made the same mistake you did once long time ago, and I thought the pads were awful. do a couple searches or call a carbotech dealer for a more technical answer.
best,
Matt
Old 10-15-2012, 08:28 PM   #248
RaceTech
RaceTech's Avatar
Drives: Race Car
http://www.race-studs.com/servlet/StoreFront
I use the bullet style on my track S4 however their are standard studs available. Ships out same day.
RaceTech is offline   Reply With Quote
Old 10-15-2012, 08:31 PM   #249
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
best,
Matt
I actually don't think the pads are awful at all. They worked great. I more suspect overheating, certainly boiled fluid obviously. Rotors look like they got mighty hot too.
I've run CT pads before, never turned/replaced rotors and never had an issue with them, but also never showed signs over overheated brakes on the other cars either. I love Carbotech and have had them sponsor ITR Expo before, great bunch of guys and pads.
You are correct in suggesting what you are suggesting, not denying that.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-15-2012, 08:33 PM   #250
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
How are they compared to ARP? I've used ARPs for years without issues so I currently plan on just going that route.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-15-2012, 09:05 PM   #251
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Is there a link with more info on the formula kit? I went through the thread but only saw the sprint and endurance.
JoeBoxer is offline   Reply With Quote
Old 10-15-2012, 09:53 PM   #252
renzo1982
Drives: White FRS
best,
Matt
I coudn't agree more with Matt. I have Matt's old Carbotech pads and his rotors, I have tracked them the last two weekends (Fontana and Buttonwillow) and it reminded me why Carbotech's are my favorite track pads.
renzo1982 is offline   Reply With Quote
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 11:34 AM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 03:36 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
