#197 |
Drives: TOYOTA
I was actually researching information on rear brake upgrades today and found this:
http://stoptech.com/technical-suppor...brake-upgrades I'm a noob when it comes to the technical stuff, but I found it an interesting read. Visually, it'd be nice to have a rear kit to balance it out, but in regards to function, you theoretically should be fine with lines and pads (and some kind of matching rotor? (so you don't go from seeing a nice j-hook or drilled setup in the front to a plain ol' blank disc in the rear lol). This kit maintains or is close to stock brake bias, so it seems there's no real need to offset any changes with a rear kit. Right? |
#198 |
Drives: race cars
I don't think this reasoning holds water. If you are changing the front brakes with a kit designed to keep the same stock braking proportion, then changing the rear would in theory need to have the same braking proportion as the stock rears.
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below. http://fecompetition.wordpress.com/ https://www.facebook.com/FECompetition |
#199 |
Site Moderator
Drives: Stuff
100% Agree. You beat me to replying to that, but this kit was definitely designed to keep the stock balance already.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#200 |
Drives: really slow...
Does Essex recommend rear brake bias adjustments via pad compounds if one was to keep the stock rears? Or do they recommend, for example 1 for 1, meaning if you use Hawk HP+ compound fronts they would recommend the same for the rears?
#201 | |
Drives: 2012 BRZ Premium WRB 6MT
A complete rear brake system on these cars for performance purposes starts to get into the realm of diminishing returns. The OEM rear equipment represents itself fairly well under track conditions as it stands. If optimized, you'd save weight, but at a substantial cost, and you'd lose the parking brake. The return on investment in the rear would not be nearly as great as it is with our front systems, which IMO are bordering on a no-brainer if you track your car. You lose nothing, and gain a broad and deep array of benefits. As a complement to our front system, I'd recommend adding the matching Spiegler rear SS lines and quality pads (to match the front). You will gain greater feel with the lines and pads (and heat capacity/torque output with the pads), and it will only cost a few hundred $. If you are more focused on Aesthetics and street driving, will be offering at least one complete four wheel brake system from AP Racing. The main one will have a newly designed six piston front caliper (that looks killer from what I've seen of it), and a four piston rear with a one-piece disc. That system will look gorgeous, and still offer performance increases over stock. They will fill an 18" wheel up beautifully, have dust seals, and a painted finish which is better for winter environments, etc.
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing www.essexparts.com ![]() Last edited by JRitt; 10-08-2012 at 11:59 AM. Reason: added info |
| The Following 6 Users Say Thank You to JRitt For This Useful Post: | Bristecom (10-08-2012), Captain Snooze (10-10-2012), Dimman (10-08-2012), Ro_Ja (10-08-2012), Surok (10-22-2012), UncleFester (10-08-2012) |
#202 | |
Site Moderator
Drives: Stuff
![]() They suggest the same pads front and rear. I'll be running AP C300 F&R for the track and AP S100 F&R for the street.
-Dave
#203 | |
Exclusive Importer AP Racing and Ferodo Racing www.essexparts.com ![]() |
#204 | |
The Ferodo and AP Racing rear pads will not be immediately available when the first production kits are delivered, but they will be within a couple weeks of our systems' launch. The car will be drivable with OEM rear pads and our front kit with race pads, and it won't present any problems. It just won't be optimized. If you want a matching front and rear immediately, we can get Endless pads in any of their compounds. From talking with Endless, MX72, ME22, or ME20 would all be good options depending on what you want.
| The Following User Says Thank You to JRitt For This Useful Post: | RYU (10-08-2012) |
#205 |
so I have the ferrodo 2500s up front. is there a ferrodo option for the rear? is there a 3rd party you all recommend for the back end?
#206 | |
Production parts update: I got an email roughly 2 mins. ago from engineering...the finished Endurance System hats have passed QC inspection and they are good to go. Sprint hats are being bolted up to discs as I write this. Sprint System brackets are being anodized this week. Endurance system brackets are still on the mills. If all goes as planned, we should start shipping production Sprint Systems out late next week. I'd guess 2-3 weeks before the Endurance Systems start going out. Thanks for your patience to all of our pre-order customers.
#207 | |
#208 | |
Site Moderator
Drives: Stuff
-Dave
#209 |
Drives: 86 GT
Hey JRitt,
Would you think there can be a difference in brake balance if this kit is used on the 86 with the smaller rear brake setup, like the base spec GT model? (australian model) GT model has solid 286mm x 10mm rear brakes. Last edited by uncivilised; 10-09-2012 at 08:21 AM. |
#210 | |
1. The master cylinder is the same on all models 2. The front calipers are identical on all models 3. The rear caliper pistons are a different size on the GT model vs. the USDM cars If you can get me all of that info I'd be happy to run the calculations and see what brake bias looks like for our front brake kit on a GT model. The other option (assuming the master cylinder is the same), would be to just put a US spec OEM rear brake setup on the car and call it a day. You'd benefit from the larger vented discs and pads on the track anyway. These will be a dime a dozen soon, as more cars are crashed and parted. Also, I believe the Legacy 2.5 GT 2010+ has the same rear brake setup as the US spec BRZ. Thanks.
| BC Racing Coilovers with Free Stainless Steel Brake Lines!!! | Dustin@Dynosty | Brakes, Suspension, Chassis | 21 | 01-08-2013 11:34 AM |
| SS Racing Brake Line | K1 Motor Works | Brakes, Suspension, Chassis | 5 | 06-29-2012 03:36 AM |
| Essex/AP Racing Competition Brake System in Development | JRitt | Brakes, Suspension, Chassis | 1 | 06-14-2012 02:32 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 11:28 AM |
