#29 |
Drives: '13 LAVA - lightly modded
Any updates on this?
You are going to be condemned to live out the consequences of your taste - TM
#30 |
#31 |
bruh
Drives: Raven 2015 FRS
fwiw Id absolutely be down to get these, basically exactly what i want.
Some rally-esque fun on a budget.
<-- why is this an emote |
| The Following User Says Thank You to FeRS For This Useful Post: | Racecomp Engineering (06-18-2018) |
#32 |
Drives: 2019 WRX
Any juicy updates?
#33 |
Veteran RallyCrosser
Drives: 10 Series FR-S, 95 Escort Rally Car
I like what I’m reading here. Speaking from 4 years of SCCA RallyCross experience with the FRs more ground clearance would be great!
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal 2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive |
#34 |
#36 |
Drives: 2014 GT86
Racecomp Engineering: no carporn pics!
#37 |
Get a Bowl
Drives: 2017 BRZ PP
#38 |
Drives: 2014 GT86
Ricepudding: most of such are 1) with custom rates, built to order, 2) stronger to handle rally-ish abuse .. think of 7.5-15K for set. And even then they often are overhauled every 1000km. Spring & damping rates are far from being compliant for daily driving though, so despite their coolness and what miraculous maneuvers & bad road surfaces & speeds they can handle, i find hard to imagine someone installing these in daily drive, even if one can stomach the price. From this class i'm more used seeing Ohlins TTX on local rally prepped subbies & evos though.
#39 | |
Get a Bowl
Drives: 2017 BRZ PP
Sent from my Pixel XL using Tapatalk |
#40 |
Drives: 14 BRZ, 16 FoSt
I just got back from my first rally-x in the BRZ. I would buy these if they were close to stock spring rate but gave more ride height. The stock setup was really good (for me) but a little low. I was definitely not craving more oversteer. The car was very neutral.
#41 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
#42 |
Drives: 2014 GT86
Unlike taller tires, spacers or longer springs don't change gearing ratio to taller, which affects acceleration. That will help with stock relatively low NA power. Tire weight and cost also is kept lower. That's why i'd prefer those for more ground clearance over taller tires.
| Gauging interest for an OEM exhaust in GTA | StraightOuttaCanadaEh | Canada Classifieds | 5 | 06-08-2017 02:00 PM |
| Gauging interest in ACE 150- Type B | olsonpg | Canada Classifieds | 3 | 07-12-2016 08:10 PM |
| Gauging Interest | ISC Suspension | Announcements, Contests, Giveaways | 17 | 04-03-2014 10:44 AM |
| Jdm headlights - gauging interest | Hawk77FT | Exterior Parts (Aero, Lighting, Etc.) | 7 | 03-31-2014 10:38 AM |
| Gauging Interest Rear Diffuser | SunkenFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 10-07-2013 05:28 AM |
