#57 | |
Sallbaru
Drives: raven FRS
#58 |
Drives: '13 GBS Subaru BRZ
The tool is a special plate that attaches to a breaker bar and has different bolt patterns that you can use to fit the holes on the pully. It isn't an exact fit for this stock pully but it works. It fits perfectly on the Perrin pulley.
http://www.grimmspeed.com/catalog/pr...roducts_id=231
#59 | |
Sallbaru
Drives: raven FRS
thanks
#60 |
Drives: 2001 Camaro
Can somebody post a video of the car's tachometer while driving, showing an example of what it drives like with the pulley on?
I've searched around but I cant seem to find a video anywhere for this vehicle. |
#61 |
Member of the year - 2016
Drives: Scion FRS
#62 | |
When in "Park" on an automatic transmission the parking pawl is engaged locking the shaft. The engine itself is basically disengaged from the transmission, and has nothing to prevent the crankshaft from turning when you apply force to the pulley. (Or at least that's what I remember about automatic transmissions in park) You either need a tool that will allow you to hold the pulley still while you turn the nut, or an impact wrench that is bother powerful enough, and will fit in the limited space in front of the pulley. |
#63 | |
Drives: Scion FRS
#64 |
__(X)__
Drives: '11 Legacy, '89 190E, '78 GS1000
having the same problem. i cant get the crank bolt to loosen. and I tried over 175 ft lb.... wtf?
![]() EDIT: got it! Last edited by Kuzuri; 08-10-2012 at 02:42 PM. |
#65 |
Driving Coach
#66 |
__(X)__
well i was using the breaker bar at first, but then switched to the torque wrench so i could see just how much force i was using. (how i knew i was over 175 ft lbs) i thought that was just nuts... so my buddy came over and we were just talking about it for a little while and hes like "just let me try it, watch ill get it on the first try" and sure enough he did... it was turned up to 200 ft lbs, and he kept going after it clicked... finally that sucker just broke loose. i guess i was just being to gentle on it... lol Last edited by Kuzuri; 08-10-2012 at 06:46 PM. |
#67 |
SLO NO MO
Well add me to the list of folks who couldn't get the damned bolt off with a 24" breaker bar (gear in 6th, parking brake pulled so hard it snapped the boot assembly off).
with the 24" breaker, I had about half a foot of "sponginess" play, and it just wouldn't go further. I was afraid of snapping something (the bar was starting to bend pretty good) and causing some serious damage to the vehicle or myself. Would the pulley removal tool help in this situation? |
#68 | |
Most likely, zero sponginess when using the pulley tool. It still takes a lot of force but you have much better control.
#69 |
That Guy
Drives: 2013 asphalt FRS MT
unless you're talking about something else, the pulley removal tool is for removing pulleys that are press fit, and our pulleys aren't pressed on. The sponginess is most likely the sprung hub on the clutch, I ran into the same thing. Just keep hauling on the power bar, it'll come off.
#70 | |
Drives: Limited WRB AT6 BRZ
| Tags |
| brz, crank pulley, diy, frs, perrin, raceseng |
| Perrin Crank Pulley now available | milenko11 | Engine, Exhaust, Transmission | 96 | 12-10-2017 07:45 PM |
| Crank Pulley and the warranty | Brimford | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-08-2012 04:47 PM |
| Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 2 | 07-07-2012 11:24 PM |
