Old 04-27-2015, 05:56 PM   #281
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
LOOOL! It looks like that guy ate amphetamine cereal for breakfast, right before he made that video. But it's pretty ingenious, nonetheless.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following User Says Thank You to Anthony For This Useful Post:
Trap63 (05-03-2015)
Old 04-27-2015, 06:56 PM   #282
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
I installed the pulleys this weekend. They are officially the first mod I've done to the car that I wish I hadn't done. Didn't notice a damn difference at all. lol:
Apex_BRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to Apex_BRZ For This Useful Post:
Anthony (04-28-2015), brybot (12-23-2016), Marrk (04-28-2015)
Old 04-28-2015, 03:43 AM   #283
churchx
churchx's Avatar
Drives: 2014 GT86
People notice when adding up to these also other lightening rotational mass mods. Lighter driveshaft, lighter wheels/tyres/lighter aftermarket brakes. As for JUST pulleys, it might indeed be below butt-dyno detecting margin, but imho nevertheless slightly improving performance.
Old 04-30-2015, 03:54 PM   #284
Apex_BRZ
That doesn't even make sense. They felt a difference because they did the other stuff. The pulleys do nothing. I have lighter wheels, tires, and some brake components. The pulleys are a placebo.
The Following User Says Thank You to Apex_BRZ For This Useful Post:
Trap63 (05-03-2015)
Old 05-02-2015, 06:01 PM   #285
Szanzar
Szanzar's Avatar
Drives: 2014 BRZ DGM
A installation video I watched on YouTube mentioned that the o-ring/gasket from the stock pulley would need to be transferred to the aftermarket one. Any input about that?
EDIT: Nevermind
Szanzar is offline   Reply With Quote
Old 06-10-2015, 06:20 PM   #286
CladMonitor
CladMonitor's Avatar
Drives: 2013 FR-S Asphalt
Love how that video doesn't address how to re-assemble with the equal torque going in the other direction ...
CladMonitor is offline   Reply With Quote
Old 06-10-2015, 09:44 PM   #287
Cooperdh
Hot Lava Lover
Cooperdh's Avatar
Drives: 2013 Scion FR-S- lava
Help!
The heavy metal piece with the little knob that goes into the pulley came out with the OEM pulley. I tried to put it back in but it won't go flush. Any suggestions?
Cooperdh is offline   Reply With Quote
Old 06-11-2015, 02:18 AM   #288
Cooperdh
Hot Lava Lover
Cooperdh's Avatar
Never mind
After about 3 hours, I finally was able to get the notch to line up. As a warning to others, when you take the OEM pulley off, do it slowly and don't let this piece come out with it. Your life will be so much easier. I had no problem getting that bolt off like others did and thought that this was going to be a piece of cake. Boy was I wrong.
The Following User Says Thank You to Cooperdh For This Useful Post:
MJones_RB (12-07-2017)
Old 06-11-2015, 11:53 AM   #289
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
The issue you faced is mentioned in this very thread and is a sticky at the top of this forum...
http://www.ft86club.com/forums/showthread.php?t=26386
It's very easy to avoid: All you do is get that bolt loose but not all the way out, hold it in place with your thumbs, and slide the pulley off onto it. Your thumbs applying pressure to the bolt will keep the little mount doohickey in place in the engine. Then, one hand hold the pulley; other hand unscrew the bolt, lift straight up and you're done. Then, install new pulley. Piece of cake.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following User Says Thank You to phobos512 For This Useful Post:
Cooperdh (06-11-2015)
Old 06-11-2015, 11:59 AM   #290
Cooperdh
Hot Lava Lover
Cooperdh's Avatar
I wish this info was included in this thread. I read every single comment on this thread and saw no mention of it. Maybe the original post should include this info. Just saying. More people discussed how hard it was to get the bolt off which was no problem for me.
Old 11-01-2015, 05:37 PM   #291
vien
Drives: subaru brz
Thanks for the tips helps alot!
vien is offline   Reply With Quote
Old 05-18-2016, 07:00 PM   #292
Bobster
Drives: GT86 GTS
Great write up thanks, I will do mine this weekend
Bobster is offline   Reply With Quote
Old 05-22-2016, 04:31 AM   #293
mb_
Ex-MR2 owner
Drives: Scion FRS
Just installed a Kartboy Crank Pulley I had lying around. Install itself was a breeze, crankshaft pulley spacer moved out a little bit but I just pushed it back in it sat properly. No wobbles or oil leaks after a 20 minute test drive.
However, I dropped the damn o-ring that sits in front of the spacer and dropped it on top of the header and slid down between the header and the engine.... had to removed the header to retrieve the damn o-ring.
mb_ is offline   Reply With Quote
The Following User Says Thank You to mb_ For This Useful Post:
Old 11-10-2016, 04:49 PM   #294
Imperius
Imperius's Avatar
Drives: Subaru BRZ
Originally Posted by bensims1 View Post
i saw this
on youtube for a cheeky tip to get the crank pulley bolt off by starting the engine while having a breaker bar not the bolt and wedged someone it won't move.
I don't know if this is much use or even a wise thing to do but i thought ill post it anyway.
Did anyone try this approach on their car ?
Imperius is offline   Reply With Quote
brz, crank pulley, diy, frs, perrin, raceseng
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 07:45 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 04:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 11:24 PM
