#239 | |
Just a dude
Drives: Scion FR-S 2013
#240 | |
Just a dude
#241 |
Not worried about compromising from torquing, more worried from using the breaker bar and have no sense of how much pressure I applied and not being sure if the "give" was completely drive train loading.
#242 |
Just a dude
I understand mine felt like I was going to need a sumo wrestler on end of a 3 foot breaker bar it's ok. I've ran mine as have several others thousands of miles after the deed and been fine..
| The Following User Says Thank You to OICU812 For This Useful Post: | 1Cor10:23 (07-12-2014) |
#243 |
Drives: 2013 FR-S Asphalt
Aftermarket Crank Pulley Install
For those automatic Owners, per the service manual here is the crank tool.
![]() 18355AA000 and 18334AA000 (one for the handle and spanner the other for the required pins. The flex tool isn't specifically recommended for our FA20 AT6. I think the lack of an inspection cover makes it a non-possibility and the starter location makes it hard to lock anything reliably. The "Cam" tool called out earlier MAY work but I think someone need to give us a thumbs up as the pin spread is very important. Also, given the cost of the SST this may be a much better solution! Amazon: OTC 4754 Universal Pulley Holder http://goo.gl/1kgEDB Lastly, keep in mind that even after you get the stock pulley off you have to get the after market one on w/o maring the aluminum. Not sure how you all are accomplishing that for the AT6. Last edited by CladMonitor; 08-03-2014 at 09:35 PM. |
| The Following 3 Users Say Thank You to CladMonitor For This Useful Post: |
#244 |
Drives: Honda Fit
Good post, CladMonitor. Thanks.
#245 |
Drives: 2013 Subaru BRZ AT JRSC
Thank you @Enigmus for this very useful guide!
I installed Perrin lightweight crank pulley yesterday. My BRZ is automatic, so it was tricky, but I made it. I didn't want to buy that special tool to hold the pulley, so I made it myself from a piece of wood I had, and some hardware (got the idea from some Subaru forums): Not the nicest looking thing, but it worked just fine. Besides, I read, that the tool designed for Subaru pulley wouldn't work for the Perrin pulley, so I had to come up with something anyway. In case of my "tool" I just drilled the holes slightly differently at the other end of my plank, and used the same bolts. But man, that crank bolt was tight! My 2' breaker bar was definitely not enough. I had to extend it with a thick metal tube (a bike holder became handy here ), and having a long plank as a pulley holder also helped. But even then it took several attempts for us to break that bolt loose!I also measured the pulleys, as expected, the weight difference is massive! (my scales are in grams of course )Haven't driven much yet, will see tomorrow, if it will help to offset the additional parasitic load from a supercharger at the low RPM. Last edited by alpax; 11-03-2014 at 02:30 AM. |
| The Following User Says Thank You to alpax For This Useful Post: | Imperius (11-10-2016) |
#246 |
Drives: 2013 GBS BRZ Limited
#247 |
#248 | |
Something like an ant's fart in a hurricane comes to mind. |
#249 | |
Would be interesting to have the actual math behind that. Frankly speaking the whole idea of replacing the crank pulley is like that "fart in a hurricane", but everyone confirms, that the difference is noticeable. The SC parasitic load is also just "noticeable" - it's not that huge. That's why I'm simply guessing they could be the values of a similar magnitude. And because "+" of a pulley and "-" of a SC happen at the same RPM range, it's just logical to try and sum them up. Actually during my morning drive today I did notice several times that the engine RPM climbed slightly easier. Could be a placebo effect of course. ![]() I wouldn't expect the crank pulley to make a huge difference, but even if it would give a slight improvement for its money - why not? |
#250 |
Drives: FRS
Toyota Tech here. I was planning to get this for my car so I started to ask around the more experienced guys at the shop, and one of the heavy line guy said he already got a few blown engine with the light weight crank pully. He works around alot of FR-S's and was also one of the techs that was invited to work at the Toyota grand prix celebrity race as a tech. Now I'm not scaring anyone away from using it, but I just want to lay the facts on the table. Also theres not much that directly links the pully to the blown engine, he just said he noticed a few of the blown ones had it and for some was the only mod as far as he can tell.
#251 |
@Enigmus tip with picture to add to the DIY at your discretion
I apologize if this has been mentioned already. I never read past the first page of the diy lol Doing mine as I type and this is how I put the belt back on, easiest possible way afaik. For the time/bs this would save I recommend taking off all pulley covers, it's another couple 10mm bolts so why not Line up belt on all pulleys & tensioner, except this top center one, while simultaneously pushing down on the belt to keep it from slipping off the pulleys you're lining the belt up onto Then when it's all lined up push down on the wrench (tighten/clockwise as mentioned) and position the belt onto this final pulley and you're done **edit lol sorry not done completely, please remember to still double check that belt orientation is correct afterwards lol Last edited by eddieflyinv; 12-14-2014 at 02:37 PM. |
| The Following User Says Thank You to eddieflyinv For This Useful Post: | phobos512 (12-26-2014) |
#252 |
@Sportsguy83 - Curious. Why are you selling your pulley?
| Tags |
| brz, crank pulley, diy, frs, perrin, raceseng |
| Perrin Crank Pulley now available | milenko11 | Engine, Exhaust, Transmission | 96 | 12-10-2017 07:45 PM |
| Crank Pulley and the warranty | Brimford | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-08-2012 04:47 PM |
| Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 2 | 07-07-2012 11:24 PM |
