#155 |
Great write up
After reading all the trouble some folks were having getting the crack bolt off, I was surprised how easy mine came off. It took me 5 minuets to finish the install (I have a Perrin CAI installed so no stock air box to remove) |
#156 |
Drives: 2016 STi DGM
This is great. Ordered 3 pulley set from Tomioka and am pretty sure this DIY will help me install the pulleys.
Unless, someone else has done this. Don't see any issues though. Sam |
#157 | |
Drives: Raven Fr-S
Sounds like straight gear/supercharger whine but low volume and completely rpm dependent, and i thought it was induction noise from my k&n filter. Your post is the only instance of this whine i have found so far. How many miles have you had the pulley on? Is it still making the noise?
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
#158 | |
Drives: '13 BRZ Ltd WRB
| The Following User Says Thank You to 2point0 For This Useful Post: | 200hp/tonne (06-05-2013) |
#159 |
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Just finished the install of the Perrin crank pulley.
Thanks for your DIY pictures. Checked here before loosening the pulley bolt. Two alternatives that others might find helpful. 1. Remove the air filter cover. Leave the air box in place. 2. Use an extension on the breaker bar. I used the handle section (about 36") from my floor jack to give more leverage. Didn't need sneakers to break the bolt loose. ;-) Thanks for the great help.
- When men make plans the gods laugh.
#160 |
Drives: 2013 Firestorm FRS
| The Following User Says Thank You to continuecrushing For This Useful Post: | Brzzee (06-14-2013) |
#162 | |
Drives: 2017 VW GTI Sport
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
#163 |
2013 BRZ
Can anyone suggest if it is a good option to use this pulley with the Vortech Supercharger?
#164 |
Drives: 2013 Fr-S
great write up
#165 |
Great write up just used it to install mine today
Sent from my DROID4 using Tapatalk 2 |
#166 |
Drives: -
To the OP,
You are a life saver, thank you! Was able to smoothly install my pulley in 30 mins flat thanks to your instructions which are far more comprehensive (read: pictures) than the Perrin one. Was surprising how much force the oem pulley required to remove. For a few seconds I thought my 30" breaker bar was gonna snap! |
#167 |
Drives: BRZ m/t
Did anybody notice the tensioner vibrating after the pulley install? Not sure if this is a normal vibration with the stock pulley..i didnt notice. The vibration on the tensioner stabilizes when there is throttle. Any input is appreciated. Thanks
#168 |
Drives: 2013 Toyota GTS 86
Excellent DIY guide mate I will definately use this in weeks to come when I recieve mine just a question, whats the name of your bumper skirt that sits underneath your exhaust pipes. Will they fit with the Aero bumper skirt? Cheer
| Tags |
| brz, crank pulley, diy, frs, perrin, raceseng |
| Perrin Crank Pulley now available | milenko11 | Engine, Exhaust, Transmission | 96 | 12-10-2017 07:45 PM |
| Crank Pulley and the warranty | Brimford | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-08-2012 04:47 PM |
| Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 2 | 07-07-2012 11:24 PM |
