86WORX
Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 03-01-2018, 08:38 PM   #29
Coachrhino11
Drives: Jeep Wrangler
Originally Posted by JSube View Post
Knee pads
http://www.ft86speedfactory.com/cata...=0&q=knee+pads
Console arm rest
http://www.ft86speedfactory.com/cata...est&q=arm+rest
And trippinbillies is right, the Sachs dampers in the 17+ PP cars provide a really good ride, plus you get proper brakes (for track anyway) and pretty wheels for $1K.
Thx for posting site, I’m in trouble now. Comparing used FRS/Miata market...fun site.
Coachrhino11 is offline   Reply With Quote
The Following User Says Thank You to Coachrhino11 For This Useful Post:
JSube (03-02-2018)
Old 03-01-2018, 08:59 PM   #30
Willie Swoopes
Junior Pizza Joe
Willie Swoopes's Avatar
Drives: 2017 BRZ Limited Manual WRB
Originally Posted by Grady View Post
You could have bought the one with the PP. found someone to give you stock breaks and struts. Sold the PP brakes, wheels and struts for $2K pocketed $1K
Hey, my time is worth something too! After swapping brakes, struts, and wheels on two vehicles, minus my time, I'd only be left with $950.
Besides, if I had them I would probably get used to it and keep it the way I bought it. I'm lazy like that.
I mean, really, I'm kinda okay with the stock Michelins. I put on winter Continentals, and I can't wait to get my summer tires back.
Scooby-Doo: Scooby-Dooby-Doo!
Shaggy: And like, Shaggy too.
Willie Swoopes is offline   Reply With Quote
The Following User Says Thank You to Willie Swoopes For This Useful Post:
Grady (03-01-2018)
Old 03-01-2018, 11:46 PM   #31
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by Rai-zero View Post
I tested a 2015 BRZ yesterday and was quite pleased for the most part except for my right knee which was in contact with the center knee pad area which is hard plastic. Wanted to ask if the new revised car has improved this with softer material?
I was looking that it’s possible to replace with some aftermarket solution but I’m not sure if I want to buy a new car and start replacing parts like this.
The factory padded knee rests were available on the JDM versions of the car from the very beginning. I had the same problem as you, and replacing those panels was one of the first things I did on my '14 BRZ. I think this is what I have, but I bought them from another member here:
http://www.ft86speedfactory.com/toyo...l#.WpjFC2rwaM8
You can find them even cheaper on Ebay. Understand that you can't just pry the panels out. You have to remove the center console first so they can slide out. That DIY linked somewhere above was excellent, but all the pics are dead. Still, it's worth a read through.
I also need to add an armrest.
You have two options for factory armrests. There's the Toyota JDM one that looks like this:
http://www.ft86speedfactory.com/toyo...l#.WpjHBWrwaM8
There's also the Scion one that looks like this:
https://www.oempartstoyou.com/oem-pa...ter-pt47818130
The flip up armrest looks better, but it pretty much renders your cupholders useless. It's also kind of low for us taller Americans. I would have to lean way over gangsta style to use it.
The sliding armrest is slightly less attractive but is considerably more functional. It allows you to slide the pad out of the way to use the cupholders and/or access your storage area and power plug. It's also taller, which was the selling point for me. I can drive comfortably with my elbow right on it.
There are some aftermarket armrest options, but IMO none of them look or function as well as the OEM options.
Old 03-02-2018, 07:37 AM   #32
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
Originally Posted by Coachrhino11 View Post
Agree about losing a bundle but if buying new an extra grand is nothing for what you get compared to Mazda charging over 3k for bbs/brembo package. Both look great!
I understand why the ND and the BRZ get compared all the time, but they're pretty different. The Mazda is a very tight cockpit without breathing space behind the seats like the Sube has. Psychologically and functionally it makes a difference. And while the ND is a great handler, the body roll in corners is mental- I like the flat attitude of the BRZ. The seats are better in the BRZ, the Mazda has very creatively designed beach chairs. But if you're a convertible guy, there's no better choice than the ND, and the RF is a cool thing. Also, the ND's engine delivers linear power delivery, I had to spend $$ to bring my BRZ "up to speed."
Raceseng Circuit Sphere 100 shifter arm, Radium catch can and master cylinder brace, Perrin oil cooler, Vorshlag front camber plates, ACE A350 header & overpipe, Berk catted front pipe, CSGxMXP exhaust, Delicious NA Stage II tune & Flex Fuel
JSube is offline   Reply With Quote
The Following 2 Users Say Thank You to JSube For This Useful Post:
jmark (03-02-2018), Tcoat (03-07-2018)
Old 03-05-2018, 10:29 PM   #33
ShansBRZ
Drives: 2017 brz
Originally Posted by Willie Swoopes View Post
I ordered my 2017 without the PP.
All the cars I found on lots had it already so if I wanted one without I had to order it.
I was looking for a run-about, not a track car. I saved 1k which I spent on winter tires and used Scion rims.
Did a lot of internet research before the purchase. When I went into the dealers I already knew what I wanted and what I was getting before ordering the car. I was answering the dealers questions in many cases.
A&T Subaru in Sellersville PA was great; no gouging, ordering and communicating well. Ordered the car and waited (the hardest part).
Then
Glad to see some one local to me. I bought mine from ciocca Subaru in south Allentown.
ShansBRZ is offline   Reply With Quote
Old 03-06-2018, 10:10 AM   #34
Rai-zero
Drives: Legacy
Just test drove a 2017 last Saturday, the knee pad is not any softer to my leg, the problem is my leg bone not the kneecap is resting directly on the console.
I did find this that may be a solution.
https://www.ebay.com/i/141933461330?...D1458776857324
Rai-zero is offline   Reply With Quote
Old 03-07-2018, 08:01 AM   #35
Willie Swoopes
Junior Pizza Joe
The knee padding on the 2017s is much thinner than those aftermarket photos (see above)
Its more of a surface covering surrounding the door speaker, and the footwell about half an inch thick.
Am I back on thread?
Old 03-07-2018, 09:29 AM   #36
Rai-zero
Drives: Legacy
Yes, the new material is leather or leather look but not soft, I’m guessing most people don’t have the same issue which I do.
Old 03-07-2018, 09:46 AM   #37
Rakshaa
Milton 86 Club
Rakshaa's Avatar
Drives: Lexus IS350, GT86, Mini Cooper, CBR
I agree some other aftermarket options are softer. Use the links people have posted in the thread for some Alcantara ones as opposed to leather, since it will be a softer feel for you.
Rakshaa is offline   Reply With Quote
Old 03-07-2018, 11:44 AM   #38
Grady
Grady's Avatar
Wasn’t there a children’s story about this?
Princess and the pea or somthing like that?
Or was it about 3 bears?
The Following User Says Thank You to Grady For This Useful Post:
Tcoat (03-07-2018)
Old 03-07-2018, 12:26 PM   #39
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Only a REAL princess can pee through 12 mattresses.
Old 03-07-2018, 01:22 PM   #40
skoobywrx
Drives: BRZ Limited, WRB
had to search all the way back to 2007 for pics, when i did this to my 05STi. But its really easy to do yourself. some spray on adhesive and some foam, and some material to cover the foam with.
skoobywrx is offline   Reply With Quote
[QUESTION] 2017 Toyota 86 In Canadian snow? milkydude12 Scion FR-S / Toyota 86 GT86 General Forum 56 10-03-2022 10:05 AM
2017 aftermarket steering wheel horn question HachiRolle Cosmetic Modification (Interior/Exterior/Lighting) 9 06-20-2022 07:30 AM
CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT DTrouble CANADA 0 07-19-2017 09:42 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 09:59 AM
Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift ModinJapan Southern California 1 01-25-2017 01:46 AM
