86WORX
Old 05-01-2018, 06:22 AM   #183
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by tomm.brz View Post
Wooo finally you declared the weight of your car : )
still wondering though how you can declare a perceived (lol) hp of 260bhp with your setup that could barely do 170whp and you don t even have a carbon fiber driveshaft
I have a build thread and you can check there. I posted acceleration measurements that were done twice and their difference was a hundredth of a second which means accuracy is pretty good. I compared these times with a stock UK car and there is a 13.3% improvement and my car has a 3.727 fd which gives a 10% worse acceleration comparing to the stock 4.1 fd in same gear. Additionally, the UK car is much lighter comparing to most US cars, because of different crash safety requirements in Europe. Do the rest of the math yourself.
If you have more questions, you can ask in my build thread or send me a pm. Let's not continue the discussion here.
Old 05-14-2018, 02:52 PM   #184
SuperTom
SuperTom's Avatar
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Justin how many back and forth tunes did it take to get right? And how much do they charge each time you have to go back and forth?
Thanks
SuperTom is offline   Reply With Quote
Old 05-14-2018, 03:24 PM   #185
Azzudien
Drives: 2017 Series Yellow BRZ
Thanks
Not Justin, but I just finished this process with Zach with the Ace350 header and it took 5 revisions for my car.
It is pretty painless process and Zach is amazingly quick at responding each time I sent in a data log.
Worst part for me was when he had me start doing 3rd gear pulls from 2000rpm's to redline, Finding someplace in New York to do that is tough.
Was no added price for the revisions, just paid for the base tune and the revisions where included with the base tune price and Zach didn't stop until I signed off that I was completely satisfied.
Azzudien is offline   Reply With Quote
The Following 3 Users Say Thank You to Azzudien For This Useful Post:
CSG Mike (05-14-2018), justinco (05-14-2018), TofuJoe (05-14-2018)
Old 05-14-2018, 03:28 PM   #186
Thanks
It varies with each car. Some cars take as few as 2, others take as many as 20.
Because this is not a one-size-fits-all tune, but rather, the tune is being highly customized to your individual engine, it's difficult to make an accurate guess. The typical range is between 3 and 8, as most behavior is known and quickly adjusted for, AFAIK.
Old 05-14-2018, 04:33 PM   #187
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
also it depends on if you follow instructions... they said a 2 minute "cruise" and thought they meant just drive around for 2 minutes so i logged to and back from the store. naw turns out they wanted a cruise control.
Breadman is offline   Reply With Quote
Old 05-14-2018, 04:36 PM   #188
SuperTom
SuperTom's Avatar
As long as they don't charge extra that sounds good that they will tweak it until its right. Thanks everyone
Old 05-14-2018, 04:39 PM   #189
Included with every tune purchased from CSG/DT.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
justinco (05-14-2018), SuperTom (05-14-2018), Teseo (05-15-2018)
Old 05-14-2018, 05:04 PM   #190
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Thanks
Everyone covered it. It took 5 or 6 revisions on the street for me, then we did a bunch on the dyno to maximize the tune as well. No charge for revisions as mentioned.
justinco is offline   Reply With Quote
Old 05-15-2018, 12:11 PM   #191
SuperTom
SuperTom's Avatar
What Catback systems are people running? It looks like the ACE ends in 2.5" (63.5mm) configuration if what I read is right? A lot of the front-pipes,catbacks are 60mm which I could see being a brick wall with all that flow coming out of the header/overpipe.
I currently have invidia catted FP, HKS legamax all 60mm meaning Id have to update everything to 2.5" as well so I have to consider that into the cost as well.
The Following User Says Thank You to SuperTom For This Useful Post:
Teseo (05-15-2018)
Old 05-15-2018, 12:46 PM   #192
churchx
churchx's Avatar
Drives: 2014 GT86
Why? If invidia's catted FP has flanges made to be used with stock headers & overpipe, you should be able to bolt it to Ace's overpipe (that is part of Ace's headers set/construction).
That is fitment wise. Flow wise/pressure drop wise you are overthinking things. Ace header works good even with stock everthing else (which probably are more resistive then aftermarket boltons you have now).
I'd consider switch only in case if before you were running those with catted header, eg. stock, and if after switch total noise gets too loud when you add in also catless header, or if those particular parts add some unpleasant drone if with Ace's.
Old 05-15-2018, 01:16 PM   #193
cjd
cjd's Avatar
Drives: 2017 BRZ
Results are good with the stock FP. Incrementally better options, see the Ace FP at 3", but then 2.4" for the rest of their system.
I have an aftermarket fp that doesn't bolt up, but it also fails to bolt up to stock... Baffles me how that made it out the door. I'll be able to fix it, just have to get a couple small welds done.
I have Thermal catback, reported weight was 8lbs lighter than reality but I have it, it's still a few lbs lighter than stock, and the sound/fit is nice... The helmholz tuning is spot on, very quiet cruising on the highway.
Old 08-15-2018, 10:50 PM   #194
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Getting ready to do a tune with 93 octane on the ACE + Delicious setup. Curious what the dyno will show after we are done compared to the data from this 91 tune! Coming soon
The Following 2 Users Say Thank You to justinco For This Useful Post:
CSG Mike (08-18-2018), nikitopo (08-16-2018)
Old 08-16-2018, 10:29 PM   #195
SuperTom
SuperTom's Avatar
Nice.
I just got finished with Zach last week. No dyno results but I'm very happy with the smoothness and pull and the exhaust is even more refined. Took 7 revisions on 93 octane to get right. And yes Zach is very quick turn around usually 24-48hrs later. Not weeks and months with other tuners
Old 08-16-2018, 10:50 PM   #196
stlgrym3
Drives: 2017 Subaru BRZ Limited
I’ve been working with Zach since last week on my ACE350+Flex fuel tune, so far I’ve done 3 revisions and still haven’t gotten the green light to pump ethanol yet until they iron out the kinks for 91.
stlgrym3 is offline   Reply With Quote
The Following User Says Thank You to stlgrym3 For This Useful Post:
Search this Thread:
Advanced Search
My Nameless header dyno results (results to follow) Simply_the_best Engine, Exhaust, Transmission 39 06-28-2016 05:09 PM
Australian Dyno Dyno Results Shiv@Openflash Software Tuning 11 07-22-2015 05:57 AM
86 Dyno results Anban AFRICA 18 01-14-2014 07:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
