#15 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Hum guys, Schrader EZ-sensors work fine.
Got a set in my winter wheels. It's even easier than using OE sensors: They come blank and you clone the original sensors into them, the car doesn't know they're different sensors, just bolt the wheels on and go, no relearn. |
| The Following 2 Users Say Thank You to RZNT4R For This Useful Post: | Busybee (05-29-2020), gravitylover (02-10-2019) |
#16 | |
Drives: 2016 BRZ Sport-Tech 6MT
#17 | |
http://www.schraderinternational.com...56_Digital.pdf Note to people who want to buy thoses kinds of programmable sensors though: while buying OE sensors you might have to visit a dealer to relearn them to the car each time you swap wheels (I've got a Bartec Tech400SD and it can't do the relearn on these cars), buying the universal sensors you'll still have to visit a competent tire shop to have them read your OE sensors and clone them to the schraders. Ideally you should do this before mounting the sensors and tires, because it requires putting the sensor right up against the TPMS programming tool. But that programming hassle is a one time deal and you can change wheels at will after that. It should also be noted that EZ-sensors, with their removable rubber valves, are much more durable than the stock densos which are molded on an aluminum stem. The valve stem can easily be replaced on the schrader for a few dollars each should anything happen (rust belt people raise your hands) instead of changing the whole sensor/stem assembly. Last edited by RZNT4R; 02-15-2019 at 07:45 AM. |
| Tags |
| brz, subaru, tpms |
| FS: Set of TPMS sensors. | GT86Dan | Wheels and Tires | 12 | 12-04-2016 09:24 PM |
| TPMS Sensors - What to Buy? | Stang70Fastback | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 01-31-2016 02:01 PM |
| OEM TPMS Sensors | airwak | Wheels and Tires | 3 | 08-16-2015 05:14 PM |
| Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? | Ahz | Issues | Warranty | Recalls / TSB | 9 | 11-06-2012 09:25 AM |
