Old 02-19-2018, 11:09 AM   #43
fika84
fika84's Avatar
http://www.ft86club.com/forums/showthread.php?t=45217
" I found that ring and pinion sets meant for a North American MK3 Supra (8" or 205mm ring diameter) will fit, but the pinion seal will most likely not."
fika84 is offline   Reply With Quote
The Following 2 Users Say Thank You to fika84 For This Useful Post:
clay217 (02-19-2018), Teseo (02-19-2018)
Old 02-19-2018, 11:49 AM   #44
clay217
Drives: 2013 scion frs , 1999 subaru legacy
sent spencer @ weir another email even though it seems pointless, try try and try and his prices are far better than mfactory ect
clay217 is offline   Reply With Quote
Old 02-19-2018, 01:20 PM   #45
RJasonKlein
RJasonKlein's Avatar
Man, you’re pretty vocal about not getting a response from Spence Weir, but I called the number listed on the website (707-315-6638) and he picked up on the second ring. He said he’s absolutely swamped and just to call him until you reach him.
RJasonKlein is offline   Reply With Quote
Old 02-19-2018, 01:45 PM   #46
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by nextcar View Post
Heads up! I have no connection and make no claims/recommendations on this...
Ebay has a listing for a New Weir Performance 4.56 gear set for FRS with bearings, seals, and solid spacer. Ends tomorrow and has a reserve; don't have any idea what it will sell for. If interested go to ebay and search "weir performance"
I was just trying to find a picture of a weir gear set to see if there were any identifying marks on it and ran across this.
I bid on this and I am assuming one of you bastards beat me on it.
NoHaveMSG is online now   Reply With Quote
Old 02-19-2018, 04:59 PM   #47
clay217
I have a few times and i am in Canada so its cost a bit every time.I am vocal cause everyone just says to use him and I am looking for other info as he is unreachable to me it seems so i rather just move along and source some. But I will give him a call thanks for the heads up....
Old 02-19-2018, 05:00 PM   #48
clay217
seems buddy out bid you by $5 i gave up early as the $ shot up
Old 02-21-2018, 01:46 PM   #49
scottman
scottman's Avatar
Drives: 13 mt fr-s
Also Canada, I called Wier and ordered mine a month ago, without any issues, and I received it 2 weeks ago.
Phones man.
scottman is offline   Reply With Quote
Old 02-21-2018, 02:21 PM   #50
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Phones man.
I have been calling Weir from the states. No response.
Old 11-23-2020, 10:59 AM   #51
Helturus
Drives: 2013 Toyota GT86
Toyota ring and pinion part numbers compatible with the FRS. Not all can be ordered in North America; I had to order mine from Japan. The only real problem with some of the third party gears is a bit of whine due to not all being helical cut.
3.58:1 - 41201-80125
3.73:1 - 41201-80050
3.91:1 - 41201-80052
4.10:1 - 41201-19605
4.30:1 - 41201-29606 (Included pinion seal will not fit)
4.56:1 - 41201-19557 (Included pinion seal will not fit)
4.88:1 - 41201-80183 (Included pinion seal will likely not fit)
5.13:1 - 41201-80300 (Included pinion seal will likely not fit)
Good luck.
...I went 4.56 with a MT, but sometimes I think I should have gone 4.88
Incase anybody digs this up in 2020 and wants to use the above Toyota part code for the 4.88:1.
Be warned it is incorrect. It has a significantly thicker spline for the pinion yoke compared to stock. Therefore the original one will not fit.
Don't make the same mistake I did
Sadly I do not have the correct Toyota part code to rectify the misinformation.
Helturus is offline   Reply With Quote
The Following 4 Users Say Thank You to Helturus For This Useful Post:
Lonewolf (12-01-2020), Spankopotomous (12-19-2020), Stonehorsw (11-25-2020), Tanstin (11-24-2020)
Old 12-01-2020, 07:29 PM   #52
nextcar
Guilt free parts vulture!
Drives: 2013 FR-S - Asphalt 6MT
Original post updated to reflect your issue
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 12-01-2020, 09:09 PM   #53
Lonewolf
Lonewolf's Avatar
Drives: Moped
Is it possible there are different part numbers for different world markets?
frs differential
Search this Thread:
Advanced Search
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 11:23 AM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 01:07 AM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 03:59 PM
Engine Builds-Reviews tg_1981 Forced Induction 17 01-13-2014 06:19 PM
FBM BRZ/FRS Shop Builds/Projects FullBlown Forced Induction 50 10-21-2013 03:10 PM
