Old 11-01-2018, 02:47 PM   #29
SpencerR
Drives: 2017 BRZ Series.Yellow
In case anyone still has issues with the shifter rubbing the top of the oem bolts. They can be replaced with M6x1.0x16 button head screws/bolts. They should definitely be included with the shifter but it's an easy $2 fix.
SpencerR is offline   Reply With Quote
Old 11-01-2018, 02:56 PM   #30
radroach
Drives: car
@mjanmohammad can you explain the weird 5th gear throw? And did you find a fix for it?
Old 11-01-2018, 03:03 PM   #31
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
The initial unit I received had a missing set screw. Ft86sf replaced it with a new unit which doesn't have that problem
mjanmohammad is offline   Reply With Quote
Old 11-02-2018, 01:50 PM   #32
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
If its not the irp short shifter, yall are wasting your money on all the $200+ short shifters when you can buy a short shifter for $80 and is an exact copy and feels just as well as the $200 ones. Save the money and buy more parts!
Dr. BRZ is offline   Reply With Quote
Old 05-16-2021, 01:35 AM   #33
Darknd666
Drives: 2017 86
I am looking for a shorter shifter so my shift knob isnt so tall, I am getting a katana handle and want the shifter lower so it isnt so tall.
Darknd666 is offline   Reply With Quote
Old 05-16-2021, 01:39 AM   #34
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Have you looked into the STi short shifter?
scion fr-s is offline   Reply With Quote
Old 05-16-2021, 02:41 AM   #35
Darknd666
Drives: 2017 86
No but i will check it out i cannot find anything on the internet showing a comparison visually. I just need a "shorter" shifter not a shorter throw, if i get that effect then ok, just want it lower.
Old 05-16-2021, 02:45 AM   #36
Darknd666
Drives: 2017 86
Just looked it up....a measley 4mm shorter, sigh �� i guess thats the best i can get unless i shell out for some custom work. Anything can be done for the right amount of money.
Old 05-16-2021, 02:49 AM   #37
Darknd666
Drives: 2017 86
The torque solutions one is 9.5mm shorter, thats better but how well is it made tho?
EDIT: the Manzo appears to be shorter, but i havent found anything supporting that.
How hard would it be to get a welder to cut one even shorter? That and the Manzo one is so cheap, i doubt its durability or reccomendations.
Old 05-18-2021, 01:29 AM   #38
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
I have heard goods things about the STI short shifter and Torque Solution short shifter. I am not familiar with Manzo short shifter. If budget is a problem, I would recommend the Torque Solution short shifter.
The Following User Says Thank You to scion fr-s For This Useful Post:
Teseo (01-16-2023)
Search this Thread:
Advanced Search
FT86 Speed Factory Kendallkab User/Vendor/Sponsor Reviews, Feedback, Comments 21 12-15-2015 04:01 PM
Top Speed Short Throw Shifter and Pulley Kit Strife26 BRZ First-Gen (2012+) -- General Topics 43 03-22-2015 11:11 PM
Six speed manual transmission 17k miles, kart boy short shifter AZ Cross Transmission and Driveline 9 12-12-2014 08:37 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
TWM short shifter review mtscaletta Engine, Exhaust, Transmission 22 11-01-2013 05:47 PM
