Old 08-05-2019, 12:26 PM   #85
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
Originally Posted by ka-t_240 View Post
TOB can be done in a couple hours especially if you have a friend or two. If you have someone that NEEDS to look at the house when you're working on it, leave trans under the car and take it off stands. We had mine done in under 2 hours.
Not sure how its a $1700 quote, pretty sure Subaru Job code is only 2.5-3 hrs and the part is under $75 bucks(cheaper from Toyota dealers)
I don't doubt I could have it out and back in rather quickly. my previous car was a 3KGT VR4. I rebuilt it from scratch and had the gearbox out more times than I can count. this is simple by comparison.
it's just getting her to understand that it's ok is really not possible. I'm going to ask around and see if I can do it at someone else's house. but that's probably not going to happen.
Old 08-05-2019, 03:13 PM   #86
Ultramaroon
fabulous
Ultramaroon's Avatar
Give yourself a full day to do it the first time carefully. It's way easier than an AWD setup, but it's different. Look carefully at how I support the engine. That's a big help. Don't bother with the clutch itself.
Old 08-05-2019, 03:47 PM   #87
echo419
echo419's Avatar
I read the DIY thread and watched a couple of videos. this is an easy job.
it's basically remove the cover pieces underneath and the exhaust.
use a ratchet strap to support the engine.
take out the pins holding in the shifter.
and then a handful of bolts holding the gearbox to the engine and voila.
lower carefully and take out clutch.
sure there's a few other steps but that's basically it.
Old 08-05-2019, 04:21 PM   #88
Ultramaroon
fabulous
It really is. That's pretty much it. Drain the gear oil so it doesn't make a huge mess when you pull the driveshaft. I've never watched videos so I don't know if they go into it.
I've seen pics of you so I know you'll have no trouble bench pressing the trans out and back. You can rest the bell housing on the sway bar if you need.
Old 08-05-2019, 05:04 PM   #89
humfrz
Well, he don't look all that strong to me - even with the red mask -
humfrz
echo419 (08-06-2019)
Old 08-05-2019, 07:33 PM   #90
ermax
ermax's Avatar
The only thing I will add is to don’t even waste your time trying to remove that rubber boot from the linkage. Get a knife and cut that crap off and don’t replace it. I managed to waste a bunch of time trying to remove it without ripping it and ended up ripping it on the way back on. Also don’t make the mistake of thinking you can release this boot from the interior of the car because you can’t. The only way off is to stretch the crap out of it.
I know it’s already been said but do not underestimate the importance of supporting the front of the engine. If the tranny doesn’t slide right off then try raising/lowering the front of the engine to get the angle just right.
There is a video of a guy removing the tranny in 20 mins and about 10 minutes of it is removing a cross threaded bolt on the over pipe. It really is that easy. So is pulling the engine.
Old 08-07-2019, 08:21 AM   #91
dynarun55
Drives: 2015 midnight blue limited edition.
Guys, can anybody post a link to the TSB relating to TOB please. Not able to find it anywhere! Thanks in advance.
So I had the '2 metal rods brushing' each other noise at lower rpms when I press clutch before. This morning, cold start, its full on squeaking when I press the clutch when the car is at a standstill. When I press the depress the clutch completely, I even got the engine to stall. How much time do I have before I need to replace the TOB.
Again thanks for all the posts regarding this topic
dynarun55 is offline   Reply With Quote
Old 08-07-2019, 12:36 PM   #92
echo419
echo419's Avatar
just dropped the car at the shop. I hate myself.
Old 08-07-2019, 01:11 PM   #93
Ultramaroon
fabulous
weak sauce i am disappoint
Old 08-07-2019, 01:23 PM   #94
WNDSRFR
Drives: FR-S,GTI
You need to replace it NOW. Before you get stranded and need a tow.
Old 08-07-2019, 01:25 PM   #95
WNDSRFR
Drives: FR-S,GTI
ermax speaks the truth. Heed his words and everything will go smoothly.
Old 08-07-2019, 02:18 PM   #96
echo419
echo419's Avatar
I'd say this song describes how I feel right now.
[ame]https://www.youtube.com/watch?v=ZJL4UGSbeFg[/ame]
The Following User Says Thank You to echo419 For This Useful Post:
Ultramaroon (08-07-2019)
Old 08-07-2019, 02:23 PM   #97
MX-5RACER
Drives: 1999 Miata
Another thing you can do is remove the lower studs and that will give you some room to spin the transmission to line up the splines on the input shaft and the clutch disc. Also, make sure you leave the transmission in gear when you pull it out. There is nothing more frustrating than putting a transmission back and having the input shaft just spin when you are trying to rotate the transmission to line up the spline. Leaving it in gear will give the transmission a little resistance on the input shaft to keep it from rotating.
DJ
1999 Miata VVT swap "Maggie"
2013 BRZ "Nancy-Drew BRZ"
MX-5RACER is offline   Reply With Quote
Old 08-07-2019, 04:15 PM   #98
Ultramaroon
fabulous
lolol....
I'll put the seat down for you.
echo419 (08-07-2019)
Search this Thread:
Advanced Search
Melted Throw Out Bearing danthedirt Issues | Warranty | Recalls / TSB 59 01-25-2018 06:32 PM
Throw out bearing Hyp Northern California 26 03-14-2017 12:42 AM
Post If You Have Had Your Throw-Out Bearing Go Bad! Bushhy Issues | Warranty | Recalls / TSB 8 10-24-2016 06:34 PM
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 11:21 AM
throw out bearing clips... Shit Luck Engine, Exhaust, Transmission 0 04-12-2014 07:34 PM
