Old 01-23-2018, 08:52 AM   #15
Docmattic
Drives: GT 86
I assume you rechecked oil levels today just to be sure?
@humfrz is referring to a mechanics stethoscope. Touch the stick to different parts in the engine bay to see where it's the loudest. You might be able to identify which bank is the problem or maybe some other part like transmission, but since it's so loud it might not help. Or might deafen you...
Yep oil level was spot on. I didn't get any low oil pressure warning yet either which after research I found should go hand in hand with a bad bearing.
It might be a dumb question but is this something ecutek software can confirm. I could just hook it up and do an analysis.
Probably won't deafen me, my ears are already going bad from my job.
Docmattic is offline   Reply With Quote
The Following User Says Thank You to Docmattic For This Useful Post:
Spuds (01-23-2018)
Old 01-23-2018, 10:13 AM   #16
snidd111
snidd111's Avatar
Drives: Scion FR-S
Just my two cents, but my alternator came loose at one point. It got worse rather rapidly, but would only rattle under intermittent loads. May be worth checking your torques.
snidd111 is offline   Reply With Quote
The Following 2 Users Say Thank You to snidd111 For This Useful Post:
Icecreamtruk (01-23-2018), Spuds (01-23-2018)
Old 01-23-2018, 10:30 AM   #17
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
My gut feeling is that ecu logs aren't going to be very useful on this one. While there is a chance you'll see something out of the ordinary, I'm hesitant to recommend pulling some logs because the info isn't worth risking catastrophic failure, if the sound has getting drastically worse over a day.
Old 01-23-2018, 01:42 PM   #18
Ultramaroon
fabulous
Ultramaroon's Avatar
It's a manual guys. It was diagnosed in about 3 seconds. It got significantly worse since I first posted. Its Lower engine. Rattling BAD. I youtube 86 spun bearing noise after they diagnosed and it sounded the same. IL need to get it towed anywhere at this point forward so it will be hard to get second opinion. The mechanic came to me today which was way above and beyond.
Search this Thread:
Advanced Search
Help needed! Check engine light after weird traction lights. dillanp86 Engine, Exhaust, Transmission 3 12-08-2016 10:17 AM
Urgent help needed to identify blown engine driftking96 Engine, Exhaust, Transmission 30 06-14-2016 11:32 PM
Nasty Enginer Noise - Help needed elchote Issues | Warranty | Recalls / TSB 22 01-22-2016 11:06 PM
e-Diagnose knock/tapping? (w/Video) DIE1000DEATHS Issues | Warranty | Recalls / TSB 15 11-18-2015 01:46 AM
Help diagnose picture from inside bellhousing toeout Issues | Warranty | Recalls / TSB 1 07-12-2015 08:57 PM
