| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: s2000
I am having an issue similar to this, not on stand still but lets say slowing down and putting it in neutral to roll over a bump, once I shove it back into 1st, It feels like I am grinding the gears, Its like the gears are trying to mesh after slapping each other 1 or 2 times and it engages. Sometimes if I don't put it in 1st hard enough, it would push my shifter out. Anyone know whats the issue?
#16 | |
Drives: n/a
Clunk when going into first gear?
#17 | |
Drives: s2000
Hmm..thats interesting, but in my case, I guess the only way for me to go over bumps is to do a complete stop before the bump and go onto 1st or try to roll over the bump, go to a stop and then go into 1st, because I am sure to stall trying to go over bumps at 2nd. |
#18 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
How low did you go?
I go over them at 30 on a 30 posted road. Suspension does what it's supposed to. Why put it in neutral? Just put in the clutch if you need to. If you're moving, 2nd works fine. Very much dislike the soccer moms that stop before each one to crawl over it in their SUVs.
"I gotta rock." -- Charley Brown |
#19 | |
Drives: Yes
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#20 | ||
When you push to select a gear, you're moving a fork between two gears on a shaft. The fork slides toward one of them, but before it engages, there are two matching cone-shaped rings that rub together with a film of oil until they are moving the same speed. Once they're matched, a ring slides into place with wedge-shaped teeth to engage the chosen gear and lock it to the shaft and you can drive away. When selecting a gear, if the difference in speed between the two halves of the synchro are very close already, (like rolling in 1st and clutching-in to free-roll over bumps) the ring may just slide into place and the wedge-shaped teeth might bump their slots and jostle a bit to engage. It's the same effect as a grind, but it's not a grind, it's more a notchy feeling. If you can still shift smoothly at high rpm, it's not a grind. I've come to understand a notchy feeling is common among cars with triple cone synchros at low speeds. Also, you may want to try an aftermarket transmission fluid if you're still using OEM. Many people have found much improved shift feel with different fluid. Quote:
So, 1st gear can be engaged up to it's maximum RPM (I'm not sure what that speed is, 40mph?), although if you're traveling fast enough to be using 2nd gear, just stay in 2nd. Say you're rolling at 20mph, and try to engage 1st, but you feel an abnormal amount of resistance. Some think this is a "lockout" of sorts, but it's in fact the synchro trying to make up a large speed difference inside the tranny. Once the speed of the input shaft is matched, the synchro engages to the gear. This resistance is smaller (only a bump) when you upshift, because the input shaft is naturally slowing down during a shift. Downshifting however, needs that shaft to speed up, so it requires the synchro to do a bit more work. |
#21 | |
You can also double clutch to engage first at speed (or any gear lower than what you're currently in), but that's a technique that takes a lot of practice. A lot of autocross guys will do this because there's typically a lot of tight turns that staying in 2nd would put you out of the powerband, but single clutch downshifting into 1st at 4000rpm is a strain. |
#22 | |
Drives: 13 SWP BRZ Prem
My car use to have a very hard time going into 1st even at 5mph, after 30k miles, it's smooth as silk 5 and under. If you want you can also double clutch into first, although it's a bit tricky to rev match it since the gear is so short. As others suggest, slow down more before going over the bump or just slip the clutch a little more in 2nd.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice 191WHP/151 ft-lb on 92 |
| The Following 2 Users Say Thank You to Imrac For This Useful Post: | unlimited86 (07-25-2014), wheelhaus (07-24-2014) |
#23 | ||
Drives: 2014 BRZ Limited
Edit: I see a couple of other people have basically already said what I'm repeating below, but I'll leave it here anyway.
On the other hand... Quote:
If you're talking about shifting from first to neutral and back to first fairly quickly, that can cause a synchronizer to goof up also. I haven't looked inside this transmission, but the way it usually works is that you have a shift sleeve that slides over the gear to engage it, with a synchronizer ring moving independently between them to help match the speed of the shift sleeve to the gear. The splines in the shift sleeve engage the teeth on the synchronizer, then push the synchronizer against a cone-shaped area on the end of the gear. Rubbing the inside of the synchronizer against that cone brings the shift sleeve and the gear to the same speed so that they can be engaged without grinding. When you pull out of gear, it takes the synchronizer a moment to spin back down. If you try to shove the transmission back into that gear too soon, the synchronizer may still be moving faster than the shift sleeve, in which case it will grind. It'll do that in other gears besides first as well. The same thing happens under normal shifting if the synchronizer is worn out. People think synchronizers wear out on the outside, where the teeth are. But in reality they wear on the inside, where the smooth inner surface rides against the gear cone. If it's grabbing against the gear cone, it will be turning at the speed of the gear and not the speed of the sleeve, so that it can't do its job. Here's a rather dull but actually very thorough video showing how it all works in a generic manual transmission. It may not be exactly like ours, but it'll give you a pretty good mental picture of what's going on. You don't even need to watch the whole thing to get the gist of it. [ame="https://www.youtube.com/watch?v=vOo3TLgL0kM"]Manual Transmission Operation - YouTube[/ame] |
| The Following User Says Thank You to extrashaky For This Useful Post: | unlimited86 (07-25-2014) |
| Parking brake clunk | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-28-2012 01:10 AM |
| Parking/Emergency Brake - "Clunk" | EsoBOFH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-24-2012 12:43 PM |
| Thud/Clunk when shifting. | erom | Engine, Exhaust, Transmission | 10 | 06-17-2012 08:08 PM |
| Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 01-29-2012 02:21 PM |
| Top gear USA | 4agze | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 12-09-2010 12:01 AM |
