| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
#15 |
Drives: 01 Echo, 01 prelude, 99 civic
#16 | |
Sent from my Moto Z (2) using Tapatalk |
#17 |
I've basically got everything out, the axles were both stuck as f*CK in the trans, both unboooted at the trans end instead of pulling out like they should, slide hammer and vice grips pulled them both out np... Damn pos. The trans fluid was bright red, any chance whoever did the clutch filled the trans up with ATF and that cocked the whole thing up?
#18 | |
#19 | |
#20 |
Drives: 13' Asphalt
You totally CAN screw up a clutch install (know a friend who bought a civic with a flipped clutch disc). id say look up the part numbers on yaris, tercel and your echo etc. somewhere probably on a Toyota Parts website there more than likely is a list of specs on the spline count and diameter of the splined end of the axle you are looking for. f the part number matches completely then you are more than likely good to go. good luck
| Tags |
| echo, manual, transmission |
| Amazon echo dot Alexa in BRZ [video] | edigeek | DIY (Do-It-Yourself) Guides | 7 | 06-23-2017 09:48 AM |
| My nightmare with my BRZ is over!! | Slade | BRZ First-Gen (2012+) -- General Topics | 17 | 09-08-2015 09:15 PM |
| 2005 Echo Hatchback | Frost | Other Vehicles & General Automotive Discussions | 0 | 12-23-2013 10:13 AM |
| Pioneer X9310BT Echo | 01s0uljah | Electronics | Audio | NAV | Infotainment | 2 | 01-24-2013 06:54 PM |
| Car nightmare | ichitaka05 | Other Vehicles & General Automotive Discussions | 30 | 09-11-2011 02:23 AM |
