#15 |
You can shorten bumpstops, they're not sacred and only a couple bucks to buy new ones from the factory if you regret it.
#16 |
Drives: '16 BRZ Limited
I have RCE Yellows on my car;
in my opinion, the car rides like stock is is only a tad bit stiffer over large bumps. Highly recommend, but as others have said you could also look into the TRD springs (rebranded eibach pro) or similar. |
#17 |
Super Saiyan
Drives: 9000 HP FRS
a mate of mine got new coilovers so im gonna throw on his old set for a little bit to decide if i wanna get some. im not looking into putting a whole ton of money right now but if i need to i will. im just wondering a decent price daily driver setup is? what else is a must with coilovers? i wanna lower about 1.2 or 1.3 inches and keep close to stock camber as much as possible so what will i need up front? will camber bolts be enough? and what about the rears? will i need lca or can i get whiteline camber bolt kit for the rear and be enough? just wanna get an idea for everything i need to have a good setup and if anyone else recommends other parts to correct the camber let me know please.
#18 | |
Drives: 2014 Asphalt FRS
It seems like you already know most of this but.. If you’re going with coilovers you don’t technically need anything, but it will make you have negative camber. So to get rid of that camber yes you are right, for the rear LCAs work great. For the front it depends. Do your coilovers come with camber plates? If so you won’t need crash bolts. However, a little bit of negative camber isn’t horrible according to what I have been reading. But I myself plan on getting LCAs If I am incorrect about any of this someone please correct me. |
| The Following User Says Thank You to Dee For This Useful Post: | ImAdopted (01-10-2018) |
#19 |
Drives: 2013 pearl white FR-S
that +42 offset basically means u can't run too much camber on those 17x9 rims FYI
#20 | |
Super Saiyan
Drives: 9000 HP FRS
#21 |
Super Saiyan
Drives: 9000 HP FRS
i know, i got other wheels in my garage waiting for when i go lower, i just mean i would like the wheels to be as vertical as possible and dont want a ton of negative camber
| Seat Rail Lowering Options with Stock Seats | DaDr00 | Tracking / Autocross / HPDE / Drifting | 21 | 03-24-2021 10:09 PM |
| I need some advice on some lowering springs. | Streich94 | BRZ First-Gen (2012+) -- General Topics | 11 | 04-17-2015 03:36 PM |
| Lowering options with (near) stock rates and adjustable dampers? | Michael Blue | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 05-18-2014 09:19 AM |
| Need advice lowering my car just a bit... | dejxx | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-08-2014 11:58 AM |
| advice on lowering car. | juanam0909 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 04-30-2013 05:23 PM |
