#15 | |
Drives: 2017 BRZ
How much drop are you after?
| The Following User Says Thank You to cjd For This Useful Post: | wparsons (01-04-2018) |
#16 |
Drives: 2015 Subaru Brz
I feel ya. I did all the performance mods i wanted already (jrsc, flexfuel, full exhaust) and wanted to do some aesthetic stuff and personally love how wearelikewise and honja did their cars. My goal is to have both function and form and not just make a show car, hense why i dont want to get bags.
#17 |
Im looking to tuck the tires in the fender. Reason i want to go coils instead of bags is because i still want to be able to go to the track if i want. And the 326 coils have really stiff springs allowing for more low lol.
#18 |
Drives: 2014 GT86
Brzxtron: Extreme drop is form only. Some hacking around may slightly reduce ill effects but not to get rid of them, so imho just forget about function bit. If you have budget (seeing bags mentioned) i highly advise limiting wish for insane lowering, instead spending that money for getting higher class/quality coilovers. If you still prioritize looks/form of extreme lowering more then compromised function/practicality/comfort/handling/performance, it's your choice you vote for with wallet, but don't expect miracles from something to fix issues/limitations extreme drop brings.
#19 | |
Because compromise ®
Drives: Red Herring
My understanding (which is exceptionally limited) of stance suspension is they have insanely high spring rates. Like in the region of 20k-50k spring rates on BRZ/FRS. I don't know if this is functional ; I suspect it is part of the stance scene. The rear suspension is travel limited as it is which leads to another set of trade-offs. But you will not be able to track with these sort rates. I make no judgement but you will have to choose which way you want to go or deal with a huge compromise. Oh look, there's that word again.
#20 | |
Drives: 2017 BRZ
Nothing cheap that'll go lower is worth a penny at the track and may lead to difficulty controlling the vehicle. YMMV. A proper track build can do with well at shows and look pretty amazing. I think tuck looks horrid, so I'm probably not a fair judge here, but...
#21 |
idk this car handled pretty well, it was on Megans when this picture was taken iirc, was basically the 2nd fastest STX prepped 86 on the West Coast last year :P
| The Following User Says Thank You to strat61caster For This Useful Post: | Leonardo (01-04-2018) |
#22 | |
Drives: 2017 BRZ
At any rate, I can confirm that handling was really good when traction was available on the SRC, 10/12k (f/r) despite very little droop travel. So you can go pretty low with a well matched setup. Dropping spring rates and going a little bit higher significantly changed how the car handles on one of the worse surfaces I typically run, in a good way. I may still have been slower overall, but who knows exactly what caused that... I may just be getting faster at about the same rate my competitors are. I can't see 20k+ rates doing well unless you're into aero that needs that much spring. Especially if it goes with being even lower.
| The Following 2 Users Say Thank You to cjd For This Useful Post: | strat61caster (01-04-2018), wparsons (01-04-2018) |
#23 | |
http://www.ft86club.com/forums/showp...3&postcount=36 http://www.ft86club.com/forums/showp...7&postcount=39 |
| The Following User Says Thank You to strat61caster For This Useful Post: | cjd (01-04-2018) |
#24 |
That low is going to handle like garbage, and super stiff springs will make it even worse (without significant aero). You need suspension travel for mechanical grip (street or track), and if you're that slammed on 20k+ springs you're not going to have enough travel for any useful grip.
#25 |
LMGTFY
Drives: 13 FRS, 91 Miata
Still think this thread needs to be stickied.
http://www.ft86club.com/forums/showthread.php?t=67345 Wanna slam your car? Cheaply? Buy some $800-$1500 coils and slam it. Will ride like crap and you'll sooner than later break something. Slam but actually DO IT RIGHT? Bags plus all the extra stuff like control arms diff spacers/risers ect that you will need to keep the car semi reliable. Coils are also an option but will also need more work to keep the car semi functional. Or like the above way, just plan on repairing stuff all the time. My point being, slamming a car properly is way more involved and expensive than just adding some crappy coilovers and lowering them as much as possible. P.S. throw any ideas about tracking the car out the window if you wanna be herrafrush. Or don't come to think of it. |
#26 | |
#27 |
Drives: 2014 GT86
Brzxton: slamming will not just impact track performance. But also daily driving comfort. So even if you'll never go to track, unless you drive only on japanese roads, imho your spine will be thankful for not doing unreasonable modding choices
. There is also such thing as "GF/significant other" test . Speedbumps and steep driveways are also less attributable to race tracks.And imho you should rethink if never going to track. It's LOT of fun/enjoyment. |
| The Following User Says Thank You to churchx For This Useful Post: | strat61caster (01-05-2018) |
#28 |
Drives: Red Herring
This.
Even with bog standard original suspension you can have fun on a track. Probably not so much with a slammed car.
| The Following 4 Users Say Thank You to Captain Snooze For This Useful Post: |
| Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! | No Limit Motorsport | Brakes, Suspension, Chassis | 204 | 05-26-2017 01:09 PM |
| Power by max coilovers | Cu0ngsayz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 01-18-2014 07:21 PM |
| ***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 1 | 10-07-2013 10:40 PM |
