#113 |
Drives: 2014 BRZ Limited
Just noticed this on my car after 14K. Glad I found this thread and know I'm not alone now. Before I read any of this, I was hypothesizing it was the FI switching over from direct injection to port injection.
#114 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Anybody actually pin point absolutely what causes this noise and not just guessing...?
My car has done this since day one. ....getting off the highway, throw it in neutral to coast, "chappa chappa chappa".... Never owned a car that did this before. It's doesn't happen all the time but it does happen from time to time. My guess is a loose throw out bearing rattling around.
#115 | |
standard setting is about 30\60, port\direct |
#116 |
Drives: BR86
Always thought the rattle was caused by low engine revs vibration which rattles clutch components even when in gear. Shitty sound but always thought it normal.
#117 | |
Drives: Whiteout frs
Car haves always been running good since out of dealer anyways...even with that rattle i dont miss at all ![]() So dont worry!! My 2cents! Hope it helps calm your worry Sent from my SGH-I337M using Tapatalk |
#118 |
Drives: 2016 Subaru BRZ
I'll bump this old thread because I've been watching my RPMs while this happens to see if the noise is tied to the engine speed or the car's speed when coming to a stop.
What I've noticed is that with the clutch out and in neutral, when coming to a stop the engine RPMs will drop down to about 500rpm and that's when you hear the rattle/knocking sound. Then the rpms shoot back up. This sounds and looks a lot like the idle fluctuation problem my car has. Idle drops to 500rpm, engine knocks/tries to stall, then shoots back up. I think when slowing down in neutral, for some reason the engine just wants to drop too much too fast. Essentially, I don't think the rattle sound is the flywheel, I think it's the engine almost stalling due to dropping to too low of an RPM. Why it doesn't do this with the clutch in and the car in gear is beyond me. |
#119 | |
Rotary for the win
Drives: BRZ, FD3S RX7
"Behold, my field of phucks, lay thein eyes upon it, and notice, tis' barren."
#120 |
fabulous
To answer the bump, this is normal. It is not the flywheel. At low RPM the firing pulses of the engine rattle the freewheeling gears in the transmission.
Same thing when lugging the engine. All the gears are always spinning. Only one pair at a time is engaged with the output shaft. The rest of them jiggle around in there.
| Tags |
| flywheel, rattle, transmission |
| Interior rattle | frsinpa | Issues | Warranty | Recalls / TSB | 132 | 03-23-2015 05:09 PM |
| Downshift rattle?? | driftartist | Issues | Warranty | Recalls / TSB | 17 | 08-03-2013 11:00 AM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 01:22 PM |
| Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 | Redline360 | Transmission and Driveline | 2 | 07-30-2012 11:01 AM |
| A/C Rattle? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-17-2012 08:46 PM |
