#29 |
We also determined it happens when the clutch is in and rolling to a stop. Now they are asking me which injection mode the car is in ( I, II, or III) when the noise occurs. That means the SOA Engineers are asking the questions
2013 BRZ Preimum #452 - Sterling Silver
#30 |
When In Doubt...
Drives: Slowww
I can imagine the engineers saying that to the dealer...dealer gets confused...engineers say "just tell the customer that, they'll understand"
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#31 |
Drives: Scion FR-S
Have had my car inspected by Toyota field eng and he stated that it's typical for this car and there's nothing abnormal to it. On the other hand, dealer sad that my complain has been filed and:
1. I'll be contacted if Toyota develops a fix. 2. Car will be fixed regardless of the warranty if something breaks b/c of this issue. |
#32 | |
auto-crosser/drifter
Drives: 2013 scion FR-S black M/T
#33 |
Drives: '12 370Z Monterey Blue
^^ this video is the Z making the same noise that I've heard in mine, and sounds similar to the previous video. Still trying to figure out if it's a normal noise. Some people saying this is normal for a lightweight clutch and it seems to happen in various models if you look on youtube. Anyone know more about this chatter? I'm almost under the impression that it's normal or part of clutch break in. |
| The Following User Says Thank You to alrashwa For This Useful Post: | Reason (01-01-2013) |
#34 | |
Waited 5 years for this
Drives: '18 MX-5 Club
I can prevent the noise during acceleration if I accelerate really slowly.
#35 |
Drives: scion fr-s
the flywheel rattle happens when i throw the car into neutral and coast towards a stop. when it happens, the rpm levels will suddenly dip from 600 to 400 rpm and then rise back up to 600 and the rattle ends. the rattle is only about 1.5 seconds in length but it is annoying.
so is this really just a "normal" thing? or should be something of concern? does the DI affect RPM levels like that? sorry, i'm not too knowledgeable about car details and all it's parts/functions. |
#36 | |
Drives: Supercharged Golf Cart
I noticed your rpm's drop right when it made that sound, then go back up a bit to proper idle. You might be a future candidate for the CEL/idle dip issue. Aha, the post right above mine says the same. |
#37 |
Drives: nissan frontier, DGM MT BRZ
#39 |
Drives: Whiteout
Reviving thread.
I have the exact same noise as in the video, but rpm do not dip. The noise only occurs in neutral and usually when braking. Also, the noise is random; does not occur even when I try to replicate the situation (rpm, braking, vehicle speed, etc) in which I heard it previously. There has to be a way to get rid of that noise. |
#40 |
Shift Down
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
hmm ive been reading this flywheel clutch chatter, and after reading all the effects that occur it almost sounds exactly how my E36 M3 does when i was driving at around 60 on the hwy, then came to a red light through it into neutral it like dips rpm makes a light chattery sound then goes away only when i am driving at like 50+ then come to a stop it might just be idle air control adjusting going from a higher rpm then suddenly going right down to idle speed. idk i worked at a euro performance shop and most bmws and mercedes ive driven kinda do that but this is all speculation.
hope this might help ease minds.
#41 |
Drives: 2013 Scion FR-S, 2010 Toyota Tacoma
My car makes this exact sound, but only when the AC compressor is on. The car has made it since it was a week old but I can't reproduce it when the compressor is not running. Has anyone else diagnosed it similarly?
#42 | |
"New hotness"
Drives: WRB Limited MT BRZ
| Tags |
| flywheel, rattle, transmission |
| Interior rattle | frsinpa | Issues | Warranty | Recalls / TSB | 132 | 03-23-2015 05:09 PM |
| Downshift rattle?? | driftartist | Issues | Warranty | Recalls / TSB | 17 | 08-03-2013 11:00 AM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 01:22 PM |
| Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 | Redline360 | Transmission and Driveline | 2 | 07-30-2012 11:01 AM |
| A/C Rattle? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-17-2012 08:46 PM |
