Old 12-16-2017, 10:23 AM   #1
redwine
Passenger seat cannot 'lock' ?
Hello,
A recent new owner of BRZ 2017.
Just want to make sure i didnt get a lemon,
hope i describe is correctly......
This is for the front passenger seat only.
Under 'normal' condition (with someone sitting on the passenger seat),
If you pull/operate the lever underneath the front side of the seat,
you can choose to lock the seat position (in term of slide forward or backward) in any position you like.
But when you move the 'Back Piece' (vertical part of the seat) all the way towards the front dash by pulling/operating the side lever,
The forward/backward sliding function will not lock.
Is this a feature or mine not working ?
redwine is offline   Reply With Quote
Old 12-16-2017, 10:32 AM   #2
JMon85
JMon85's Avatar
Drives: 2019 WRX
Yup learned that loading my winter tires in lol..
JMon85 is offline   Reply With Quote
Old 12-16-2017, 10:39 AM   #3
redwine
So i purpose that is for the rear passenger to 'unload' themselves
Old 12-16-2017, 10:59 AM   #4
Yep. That is exactly what it is for. Pain in the butt when trying to clean the back seat though.
Old 12-16-2017, 11:57 AM   #5
ermax
ermax's Avatar
Standard feature. What I have noticed is you can pull the side lever and then push it all the way forward and then press down lightly on the lever you normally use to adjust the seat position. You will have to pull it back up to release it though.
It’s tempting to take the whole thing apart and see if there is some way to fabricate a fix.
The Following User Says Thank You to ermax For This Useful Post:
funwheeldrive (12-17-2017)
Old 12-16-2017, 11:59 AM   #6
ermax
ermax's Avatar
Oh also so you know. It’s also a standard feature for the doors to slam on your legs.
The Following 3 Users Say Thank You to ermax For This Useful Post:
funwheeldrive (12-17-2017), Tcoat (12-16-2017), Ultramaroon (12-16-2017)
Old 12-16-2017, 02:00 PM   #7
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
There are a few thought processes of the Japanese engineers which have not changed much since the 1970s.
It's actually nice to occasionally retain some old ideas.
ToySub1946 is offline   Reply With Quote
Old 12-16-2017, 03:40 PM   #8
Until it gets really cold out and then they don't want to close at all.
Old 12-17-2017, 12:13 AM   #9
Poodles
Drives: 2015 Series.Blue
It's to allow the seat to slide forward for someone to get in/out and then you move the back of the seat rearward and it will relock. 100% normal and as designed for any 2+2 car I've been in.
Old 12-17-2017, 07:27 AM   #10
ermax
ermax's Avatar
Most cars when you pull the side lever they will unlock the slide rail when the seat back is in the full forward position. You can then slide the seat all the way forward and then it will lock into place. When you are ready to put the seat back you simply recline the seat a tad which will unlock the rail and let it slide back to where it was. It’s this locking mechanism that is missing on our cars. Our cars will not stay forward long enough to access the rear seat and it’s annoying as hell.
Old 12-17-2017, 09:57 AM   #11
funwheeldrive
IIRC, my old Prelude, Integra, or Eclipse ever had this issue. I've never owned a car where the locking mechanism was simply left out.
Passenger seat movement lock? (stock setup) BULLITT Cosmetic Modification (Interior/Exterior/Lighting) 16 03-17-2018 05:34 PM
Passenger Seat Belt Warning Chime goes on even though there's no passenger. idreamofdrifting Issues | Warranty | Recalls / TSB 58 10-11-2017 10:31 AM
CG Lock Seat Belt Lock Biggins Interior Parts (Incl. Lighting) 0 02-03-2014 08:41 AM
Passenger seat belt warning when I put phone on seat!??? Kayzer Soze BRZ First-Gen (2012+) — General Topics 20 09-13-2013 11:29 AM
CG Lock - Seat Belt Retainer to Hold You Firmly in Seat Jimbo Miscellaneous 0 07-23-2012 01:27 AM
