Old 12-15-2017, 03:34 PM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by FunnyGopher View Post
Oh no, I watched that party happen. No flame here. I made this thread to point out the fact the GReddy one uses the stock throttle body in it's design, because that's amazing.
The SARD version doesn't have any type of valve or actuator unit to replace the factory throttle body mechanism, so I am guessing it reuses the factory TB as well.
The "tune" that SARD wants to sell with the kit seems like an average off the shelf ECU tune, plus there is no requirement to buy another throttle body.
Old 12-15-2017, 03:57 PM   #16
Originally Posted by 86_IT View Post
Mike, if you want an NA Full Ace setup to test on, I can be your guy.
CSG has a 2017 test mule with a full Ace setup . I suspect multiple ITBs may be tested on this car. Currently the test mule is boosted, but that's been on and off the car several times.
Just to clarify, my 2017 is my own 2017.
Old 12-15-2017, 06:33 PM   #17
86_IT
86_IT's Avatar
I figured. Just saying
Instagram: 86_IT Twitter: 86_IT_BRZ Facebook: 86itbrz Youtube:86 IT
86_IT is offline   Reply With Quote
Old 12-15-2017, 08:42 PM   #18
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
We need catless results, not catted. We know how strict Cali is with their emissions.
Dr. BRZ is offline   Reply With Quote
The Following User Says Thank You to Dr. BRZ For This Useful Post:
Teseo (12-15-2017)
Old 12-15-2017, 10:41 PM   #19
86_IT
86_IT's Avatar
I'm fully catless. I live where there is no smog testing.
Old 12-15-2017, 11:47 PM   #20
Where in California do you live where there is no smog testing?
86_IT (12-16-2017)
Old 12-16-2017, 12:04 AM   #21
86_IT
86_IT's Avatar
Northern Sonoma county.
Old 12-16-2017, 12:49 AM   #22
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
Originally Posted by mav1178 View Post
Well, there were 2 new things I learned from this thread that wasn't in the other threads. 1. The itbs are linked to the oem throttle body which i assume is for ecu tuning purposes 2. Greddy has a plenumless velocity stack option on the way
It seems like both the Sard and Greddy kit use AE111 4A-GE itbs. So that would mean any difference in performance would be strictly from the airflow from the different plenum designs. Really excited to see testing results!
cyde01 is offline   Reply With Quote
Old 12-16-2017, 04:06 AM   #23
mav1178
mav1178's Avatar
https://www.bar.ca.gov/pdf/Program_Map.pdf
A lot of places in CA don't have a smog requirement. Emissions checks mostly fall in line with topography, i.e. areas of the state where pollutants collect at lower elevations and are an issue.
As I mentioned before, I'm fairly certain SARD uses some variation of the OE throttle body as well, there's no requirement to buy the ECU tune as part of the throttle body and my emails with Japan have not revealed any need to buy a throttle body replacement of any sort. The kit itself does not have any motor mechanism for the ITBs either.
The Following User Says Thank You to mav1178 For This Useful Post:
86_IT (12-16-2017)
Old 12-16-2017, 04:10 AM   #24
I might need to figure out a way to register in your zip code.
There's a few of those down here in SoCal too, but I have no idea what the zip codes are.
86_IT (12-16-2017)
Old 12-16-2017, 04:35 AM   #25
mav1178
mav1178's Avatar
https://smogcheck.ca.gov/pdf/Program_Map.pdf
https://smogcheck.ca.gov/pubwebquery...ZipLookup.aspx
Any address in Inyo County, for example. So any of the towns on your way up to Mammoth.
Or Julian, CA 92036.
86_IT (12-16-2017)
Old 12-16-2017, 04:53 AM   #26
NRXRaptor
But how would it fit with a supercharger? And which one?
Definitely not the edelbrock lol
NRXRaptor is offline   Reply With Quote
Old 12-16-2017, 04:54 AM   #27
NRXRaptor
No smog testing here in mendocino county either. Lots of country bumpkins rolling coal
The Following User Says Thank You to NRXRaptor For This Useful Post:
86_IT (12-16-2017)
Old 12-16-2017, 11:38 AM   #28
gtengr
Drives: 2017 BRZ
The Greddy also comes with a throttle body synchronizer and electronic AFR dongle for equalizing the cylinders. And agree on anticipation for the results. I'm guessing they will have notably different torque curves. People will probably be experimenting with their own stacks soon too since getting the mechanicals sorted is the hard part.
gtengr is offline   Reply With Quote
ITBs finally for sale Trust86 Engine, Exhaust, Transmission 32 01-15-2018 03:11 AM
How to build ITBs celek Engine, Exhaust, Transmission 62 05-20-2016 02:20 PM
Dat sound - ITBs RWD_only Engine, Exhaust, Transmission 88 11-18-2014 05:19 PM
20v ITBs Nafe NEW ZEALAND 4 05-20-2014 09:03 AM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 07:09 PM
