Drives: 2300LB FRS
17x9 vs 18x9.5 for track use?
I'm stuck between the benefits of each tire. The 18x9.5s can fit a 265, but weigh a tad more. The 17x9s are lighter, but are usually ran with a 245. Which is more important to you, lighter weight or more tire width?
18x9.5s ![]() 17x9s
Wise old man
Drives: 86 GTS
i am running 17x9 right now with a 245/40
i am planning on running 18x10 and 285/30R18 because everybody else does that who is competing in time attack and if i dont have the same level of rubber on the road i wont be competitive. it is what it is. |
Drives: 2300LB FRS
That's what I've noticed. I'd be right in the middle with 18x9.5s. That's what I'd prefer.
Drives: '13 Whiteout
Honestly? If you're new to tracking stick with stock tires and wheels. You'll learn a ton about slip angles. People are too quick to put on sticky tires when starting to track.
| The Following User Says Thank You to TommyW For This Useful Post: | HachirocksU (09-25-2019) |
Drives: 2300LB FRS
I've been on track, no worries. I beat the snot out of my stock tires and suspension before upgrading. I'm just curious about everyone's opinions on the matter.
But did you learn to be a better driver. Throwing a car around is one thing however learning car control is another issue. Beating the snot out of your equipment is no gauge of being a good driver.
Drives: 2300LB FRS
Of course. There's always things to take away from every session. It'd be extremely naive to throw a car around without the intent of taking something away from it. I'm not here to discuss my driving, though. I'm here to discuss whether or not members prefer a wider tire or lighter wheel when it comes to wheel sizes.
Drives: 2017 Toyota 86 M6
Mmm stock power with 285?? Im run 17x9 with 245/40 and next i would go with a 255/40.
Wise old man
Drives: 86 GTS
i wouldnt go over 225/40R18 on stock power.
i was 0.4 seconds slower on 245 than 225 on stock power. |
#10 | |
| The Following User Says Thank You to TommyW For This Useful Post: | cactus (12-14-2017) |
#11 |
Drives: 13 SWP BRZ
17in tires being cheaper is a big reason to stick to 17s. 17x9 with a 200TW 245 or 255 is a lot of tire for an NA car.
#12 |
Drives: 2017 Subaru BRZ
Do you have that much power to need a 265 or wider tire? I know experienced drivers who have said they’re faster on a narrower tire.
#13 |
225's on a 17x8 at stock power, unless you're only looking to be competitive in autox, then 17x9 with 245's.
#14 |
Drives: 2300LB FRS
| Tags |
| 17x9, 18x9.5, tire size, track, width |
| WTB: RPF1'S 17x9 or 18x9.5 | ReeceR34 | Want-To-Buy Requests | 1 | 02-09-2017 11:48 AM |
| 17x9 and 18x9? | Higher Being | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 05-28-2015 01:45 AM |
| WTB: 18x9.5/ 18x9/ 17x9/ 17x9.5 Square With or without tires | loogs | Wheels and Tires | 11 | 12-08-2013 03:40 PM |
| Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** | LSD Motorsports | Groupbuys | 246 | 08-29-2013 01:35 PM |
| F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires | SsmoothyMonster | Wheels and Tires | 17 | 09-24-2012 01:52 AM |
