Old 12-19-2017, 09:43 AM   #15
FrsGT861986
Drives: 2013 FR-S Raven
Im almost pos everything is stock the previous owner was a business in texas. The slave only broke when the fork seized up. I argued and argued with the service manager about that line not be able to cause the fork to do that, he just repeated the same thing its modified im not covering anything, till he hung up on me. I called toyota corp. But im sure there gonna side with that dude
FrsGT861986 is offline   Reply With Quote
Old 12-19-2017, 01:13 PM   #16
Hades
Hades's Avatar
Drives: 2013 Scion FRS
Damn, sorry to hear that. Any other dealers in your area perhaps?
If you end up having to get it done yourself, might want to look into an upgraded clutch fork.
Hades is offline   Reply With Quote
Old 12-19-2017, 01:29 PM   #17
humfrz
Well, that's too bad.
Was there any other reason the dealership refused to do warranty work on the clutch ..... ??
I just have a feeling there is a "the rest of the story" ......
humfrz
Ultramaroon (12-19-2017)
Old 12-19-2017, 02:24 PM   #18
cjd
cjd's Avatar
Drives: 2017 BRZ
Obviously not all stock, if the line isn't... why was that replaced?
The Following User Says Thank You to cjd For This Useful Post:
Old 12-20-2017, 05:34 PM   #19
Hyper4mance2k
Shadetree Project Ratchet
Hyper4mance2k's Avatar
Drives: series.Blue
They are obligated by law to fix your car. Modifications DO NOT void a warranty. They need to prove, through legal arbitration, that the clutch line caused the fork to bend the shitty clutch fork, and bending clutch forks is a common problem on this platform. You are protected by the Magnuson Moss Act. Do NOT take no for an answer.
If the car has an aftermarket clutch pressure plate, you're screwed. It's likely the cause for the failure.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
Hades (12-20-2017)
clutch fork, throw out bearing, transmission
FS: Passenger Side Mirror Housing(non heated) OmarGC Exterior Parts (Aero, Lighting, Etc.) 1 10-13-2016 12:53 PM
Clutch pedal side to side movement? nickmerronesucks Issues | Warranty | Recalls / TSB 12 05-10-2016 08:01 PM
Side view mirror moving by itself pushrod Issues | Warranty | Recalls / TSB 8 02-12-2015 05:52 AM
WTB: OEM BRZ headlight housing (driver side) Interflop Exterior Parts (Aero, Lighting, Etc.) 0 09-22-2014 01:53 PM
Driver Side Speaker Housing Rattle Lefty Scion FR-S / Toyota 86 GT86 General Forum 2 06-12-2012 11:32 AM
