| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 | |
Junior Pizza Joe
Drives: 2017 BRZ Limited Manual WRB
Scooby-Doo: Scooby-Dooby-Doo!
Shaggy: And like, Shaggy too. |
#30 | |
Huge E85 fan!
Drives: 2016 Scion FRS
86's have no torque steer at all. There isn't enough torque even if it was FWD. The mechanic may not know this car and may assume that it is FWD (I get that sometimes- people are surprised it's RWD) or is intimidated by a car he knows nothing about but since it's a flat 4 he assumes it's wierd or whatever. Bottom line- don't go to this hack again with this car. |
#31 | |
This guy has absolutely no clue what he is talking about. If you have two different tires on the drive wheels you will obviously have pull. If the larger tire is on the rear right then the car will pull to the left on throttle and pull to the right off throttle. It’s very basic physics. Funny he thinks the electronic PS should compensate for this. Hahaha |
#32 |
Problem with torque sensor?
The torque sensor on this car is to detect the load we are putting on the steering wheel so it knows how much PS assist to give. There is a calibration process you can do in Techstream. But even if this sensor was off it wouldn’t cause the car to turn one way or another. It would just make the wheel overly heavy or overly light.
#33 | |
Or have a half shaft the runs from the diff to the other side and mounted to the back of the block then from there it has an equal length axel to the wheel. |
#34 |
Drives: 2017 BRZ
It only requires a difference between drive wheels. It doesn't need a lot of torque. In this case, there was a difference due to tires. FWD nearly always have it because of different axle lengths.
Its a different beast with a high torque engine, but that doesn't mean its not a thing without.
| The Following User Says Thank You to cjd For This Useful Post: | ermax (12-10-2017) |
#35 | |
Agree. I had torque steer on my old Integra which had equal length axels and less torque than the FRS. I will never go back to FWD if I can help it. |
| Torque app problem | Mikeez | Issues | Warranty | Recalls / TSB | 20 | 10-25-2014 05:12 PM |
| Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 09:11 PM |
| Question on sensor placement for the Torque app. | zooki | Engine, Exhaust, Transmission | 2 | 01-01-2014 06:20 PM |
| Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? | Acree | Engine, Exhaust, Transmission | 2 | 08-26-2013 07:39 PM |
