#99 |
Drives: toyota 86 2017
High beam draws more current than low beam
Here's something peculiar. I was looking at the tech manuals 86 2017 and noticed that the the high beams uses more current than the low beam. If it's a device blocking the beam that uses 5 watts that would explain it.
Tech Manual High Beam/Low Beam Headlight 34/29 watts. |
#100 |
Drives: 10 Series #895
Got a three prong switch for my fogs but the wires from the harness have 4. Two reds hots and the other grounds? Or will this switch not work?it has a blue led status light too.
![]() ![]() Sent from my SM-G950U using Tapatalk
PDX86 / 86 Sessions / 86Squad / DarkSquad
#101 | |
Drives: 2013 WRB BRZ Limited
You need to buy the specific switch and harness specifically for your car. Ok ne set is for illumination and 1 is for the fogs if I remember right. https://parts.westcoasttoyotalb.com/...oaAg_vEALw_wcB https://www.ebay.com/p/8416012060-TO...ff46c58&chn=ps -B |
#102 | |
#103 |
Drives: 2015 Firestorm FRS
Hello guys. Can i use 2017 brz headlights to my 2014 frs? Thanks
#104 |
#105 | |
#106 |
I removed the ground and now I get the led on the switch but nothing to the fogs. Oh and then I found an issue. I have a bare wire touching metal. So i fixed that but still no lights.......
#107 |
Upgrading the relay harness. If that doesn't work then I have to check each individual wire for continuity.
#108 |
#109 | |
#110 |
Ok new relay harness in and..... nothing. Wires instantly getting hot. Damnit.
#111 |
#112 |
Sure cant hurt
| OEM foglight install question | DarkSideFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-12-2017 04:21 PM |
| FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides | Verge | Exterior Parts (Aero, Lighting, Etc.) | 12 | 11-21-2014 09:56 PM |
| Automation Lighting offers HID xenon headlight + foglight kits | jjdrivesajazz | Exterior Parts - Lighting | 138 | 01-13-2014 02:19 AM |
