Old 03-13-2020, 02:45 AM   #267
raffy_vor_lengg
raffy_vor_lengg's Avatar
I have not tried opening these headlights. I have done several of OEM headlights of different cars.
What are you using? I typically use around 200F/100C. You might need to try to pry them apart in the beginning then put them back in for five minutes and try again then do it again. Maybe have someone help with a dryer or heat gun (on low), while you pry, and just make sure there are no retaining screws.
The thickness of the plastics are probably cheaper than OEM, so just be careful prying.
I tried with 200F/100C for about 20minutes, thats what went well for the OEM's. But on the VLand the sealant is still firm at that temperature.
So can i go higher? Let's say up to 300F/150C. Or could i damage the headlight? I already see that the black plastic has not that oem quality.
I do not own a oven this size, but i made a chamber out of cardboard and heat up the inside with a heatgun. There is no direct air flow on the light.
But still no way to pry without too much bending...
raffy_vor_lengg is offline   Reply With Quote
Old 03-13-2020, 04:52 PM   #268
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I would use a wood cutting board or something to make sure the part isn't touching anything metal, especially something like a wire oven rack, and I would use an oven; the cardboard isn't insulated enough, so I doubt the internal temperature is getting hot enough in a consistent and even way.
Try 225F then 250F. No reason to jump up to 300F. The other thing is 400F is roughly the melting point for injected molded plastics, but the deformation point is probably much less.
Remember the heat wave in Arizona? It doesn't take much heat over time to deform plastics.
Old 03-13-2020, 06:22 PM   #269
degozaru
Drives: 2016 oceanic frs
Hey guys. I bought 2017 tail lights a while ago and I had a new gasket put in. Today was the first rainy day and it seems that I didn't do my headlight gasket well enough or something. I was wondering how I can get this condensation out of my taillights? Or am I screwed and have to open it up?
On that note, anyone ever open up these tail lights?
Can I reuse the gasket once I get it out?
degozaru is offline   Reply With Quote
Old 03-13-2020, 10:40 PM   #270
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Indirect heat method. Cardboard box and hairdryer/heat gun
EndlessAzure is offline   Reply With Quote
Old 04-16-2020, 04:29 PM   #271
H_K
Drives: '13 Scion fr-s
Any instructions/guides for putting MY17+ 86 headlights into a 13-16 frs?
H_K is offline   Reply With Quote
Old 04-17-2020, 05:51 AM   #272
KAR
Drives: Whiteout 6spd
can you point me to the right direction for a DIY to activate my stock fogs with the parking lights.
13 FRS with stock harness, switch and fogs
KAR is offline   Reply With Quote
Old 04-17-2020, 10:38 PM   #273
bigred18
MJLONIR Program Member
bigred18's Avatar
Drives: 2014 Scion FR-S
Heyo! Got some Spec-D headlights 5 years ago (2014 FRS) and can't find a good bulb to throw into them to make 'em brighter. It may be wiring/bulb choices, but my brights aren't bright and my normal running lights are a measly yellowish white. They look more like normal car lights even though I tried a few different bulb choices. Is there an HID/LED kit I could possibly try with the '14 Spec-Ds or an easy bulb to swap out for a brighter output?
P.S. I know the exterior lens needs cleaned, just wondering about bulbs.
Thanks in advance!
ドラゴンに乗る
Instagram: Komodo_Actual
My car build: http://www.ft86club.com/forums/showthread.php?t=81094
bigred18 is offline   Reply With Quote
Old 04-24-2020, 04:09 PM   #274
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Thanks in advance!
Hey this is a great product for restoring your headlights, if you want to clean them up
CERAKOTE Ceramic Headlight Restoration Kit https://www.amazon.com/dp/B084RQKLV8..._tHZOEbY6BNP66
Sent from my Pixel 4 XL using Tapatalk
Rican_D is offline   Reply With Quote
The Following User Says Thank You to Rican_D For This Useful Post:
bigred18 (04-24-2020)
Old 05-27-2020, 07:14 PM   #275
letmethefuqin
Drives: 86
Hey!
I've got a set of spec d headlights out of a GT
whats involved in fitting them into a gts?
Thanks
letmethefuqin is offline   Reply With Quote
Old 06-03-2020, 01:34 PM   #276
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
@HeresMyMind, is it possible to wire LED fogs to the DRL connector on 13-16 BRZs?
Old 06-05-2020, 03:23 PM   #277
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
yes. you can just run a basic relay setup for this.
wires from battery to relay then to fog lights. the trigger wire from the oem running light to the relay.
-B
HeresMyMind is offline   Reply With Quote
The Following User Says Thank You to HeresMyMind For This Useful Post:
Yoshoobaroo (06-05-2020)
Old 06-05-2020, 03:25 PM   #278
HeresMyMind
Thanks in advance!
Find what bulb type those spec-D headlights use. It may be either D2S or H1.
goto www.theretrofitsource.com and order replacement bulbs / ballasts (if you currently have halogens). I do not recommend LED bulbs at all in projectors.
-B
Old 06-05-2020, 03:26 PM   #279
HeresMyMind
I do not have that, but i'm sure there are write ups here with the pin outs.
-B
Old 06-05-2020, 04:54 PM   #280
HaXx
Drives: jrsc_brz
I did this with a brz w stock fogs. Tj hunt has a video and I did EXACTLY what he did in the video and it's one of the favorite thing of my car now. I have the C lights on and the fog lights on at the same time. Ie: fogs are on with running lights. The thumbnail of the video says something like "dealerships hate him!"
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
OEM foglight install question DarkSideFRS Cosmetic Modification (Interior/Exterior/Lighting) 3 06-12-2017 04:21 PM
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides Verge Exterior Parts (Aero, Lighting, Etc.) 12 11-21-2014 09:56 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 02:19 AM
