#141 |
Drives: 2017 Toyota 86
Trying to fit Spec-D headlights onto my 2017 GT86 but the pins are very different. Any way you can show me a diagram that's friendly to someone who's just starting out on learning to do DIY their own car? Tia.
#142 |
Drives: '15 BRZ Limited
I'm contemplating a fog light retrofit. Anyone know off hand if a Morimoto Matchbox projector will fit in a 2015 BRZ fog light housing?
https://www.theretrofitsource.com/bi...box-2-562.html
2015 Subaru BRZ Limited AT6 |
#143 | |
Drives: 2013 WRB BRZ Limited
There is also plenty of room behind the foglight. -B |
#144 |
Drives: 15 FRS, 15 GTI, 88 928, 92 Skyline
I installed the Spyder Foglights this last weekend and the relay wasn't sending power to the interior switch. I replaced it thinking it was bad tonight and the same issue! Do you have any suggestions as to what could be causing this? Thank you in advance!
#145 |
Drives: 2013 WRB BRZ Limited 6MT
Hey HeresMyMind, I've done an STI-R lense swap coupled with some of morimoto's xengreen bulbs a few years ago. I like the output but i never could get the cutoff just right. I think the driver's side is solid, but the passenger side is a bit frowny and I couldn't really get it right. Do you have any tips for getting the cutoff right and optimizing the setup? I don't mind pulling the lights apart again as long as I can get it right. Your pictures look really good.
Thanks, Balf |
#146 |
MTXclusive
I also wanna know how to wire them onto a 2017+ 86 if anyone is kind enough to help that’d be greatly appreciated. Thank you!
2017 Toyota 86 l Progress/Build/Update Thread
#147 | |
-B |
#148 |
Drives: 1995 Ford Probe
Anyone replace their stock foglight bulbs in a 2018/2019 BRZ limited? What brand and bulb type did you go with?
HID? LED? ie: auxbeam? |
#149 | |
Purchased 6/22/12
So if I go buy a RX350's bixenon projectors from toyota, they slide right into the fr-s's H11 sockets? And the electric connection fits and everything? ![]() edit - also, if I'm interested in the Morimoto HID kit, should the '13 fr-s be H11A or H11B? Edit 2 - nevermind, it looks like H11B. Feel free to confirm. My other question is can you run H1 HID's DRL and High beams? Or will I lose the DRL functionality? https://www.theretrofitsource.com/h1...ect_restrict=1
#150 | |
Ontop of the projectors install, you will need to purchase D2S Hid Bulbs, and D2S ballast and adapters to plug the ballast into your OEM low beam wiring. -B |
| The Following User Says Thank You to HeresMyMind For This Useful Post: | Bonburner (12-11-2018) |
#151 |
#152 | |
https://www.theretrofitsource.com/mo...cion-gt86.html -B |
#153 |
Drives: '23 BRZ Limited 6MT; '13 FR-S 6MT
I have a question, so I have an FRS and I recently put on a 2013 BRZ bumper. How do I get the BRZ LED strip DRL's and foglights to wire up? My FRS has optional DRL strip LED's, but they don't seem to match up with to the harness that the BRZ uses. Any help or part names/numbers would be appreciated. Thanks
#154 | |
There should be one fog light wires from your FRS car harness. The running lights will have to be connected to the oem headlight running light widespread. You’ll probably have to use universal connectors or solder them. -B |
| The Following User Says Thank You to HeresMyMind For This Useful Post: | DriveDriftDogfight86 (01-28-2019) |
| OEM foglight install question | DarkSideFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-12-2017 04:21 PM |
| FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides | Verge | Exterior Parts (Aero, Lighting, Etc.) | 12 | 11-21-2014 09:56 PM |
| Automation Lighting offers HID xenon headlight + foglight kits | jjdrivesajazz | Exterior Parts - Lighting | 138 | 01-13-2014 02:19 AM |
