Old 12-05-2017, 08:12 AM   #15
Originally Posted by Decep View Post
Yeah, i get it, but better to spend the money now and do it right imo, especially on the suspension on this particular car.
Again, just my 2 cents. I've never lowered one of these cars but i've lowered Hondas and Mercedes in the past (never a lot, 1-2 inches), they always have that underdamped, slightly bouncy feel right afterwards and its only downhill from there. I'd end up doing the work again later replacing the struts with a shorter stroke strut/shock. If the stock struts on the FT86 are that much stronger than other cars go ahead and tell me im talking out my ass, i wont get offended
You are talking out of your ass (you said it was OK). Spring with the proper rates for the stock struts do not show those symptoms on these cars. The trick is to buys something designed specifically for the car though. If you cheap out then you may have issues. Going with a cheap set of coil overs will end up being a bigger problem than lowering springs on these cars would ever be.
Leonardo (12-05-2017), Qadthane (12-05-2017)
Old 12-05-2017, 09:07 AM   #16
Darth Khan
I think therefore.....
Darth Khan's Avatar
Drives: Toyota 86 860 Halo White (Manual)
If just looking for a simple drop then some lowering spring are probably a more cost effective purchase than cheap coil overs. I have the RSR Superdown springs and am very happy with them. At under $300 they are a much better bet than coilovers.
http://www.ft86speedfactory.com/rs-r...l#.WiXpc0qnGUk
Interesting couple of question:
  1. How long did you drive the car before fitting the springs.
  2. How much did it lower your car.
  3. How do you feel it affected the DD riding of the car as opposed to stock spring.
I know that ride quality is somewhat subjective and after a while of driving in a lowered car you adapt. However based on your posts and annual mileage I would suspect we have the same preferences when it comes to lowering the vehicle.
I like the slightly lower look but prefer the stock spring rates etc for normal commute and DD driving . Have no intention of racing the car, might pop into a couple of auto cross events but that would be no more than a couple of times. (I'm too old to care that some millennial+ is faster round a track)
May the N.A. force be with you.
Darth Khan is offline   Reply With Quote
The Following User Says Thank You to Darth Khan For This Useful Post:
Old 12-05-2017, 09:18 AM   #17
Here you go. http://www.ft86club.com/forums/showthread.php?t=73739
I will add that after riding around in Ultra's car for several days mine has an ever so slightly rougher ride. Not much but it is there.
Leonardo (12-05-2017), monkeybike (12-05-2017), Teseo (12-05-2017)
Old 12-05-2017, 09:29 AM   #18
monkeybike
Drives: 86
I've been a fan of RS*R in the past but you don't hear much about them with this platform.
I just had a dig and it looks like they do different rates for each model?
The spring rates F3.2kg/R4.5kg for the 86 and F3.2kg/R3.9kg for the BRZ.
Very interesting.
monkeybike is offline   Reply With Quote
Old 12-05-2017, 09:36 AM   #19
The owl Talon
Ok, I think my descion is going with the SCION FR-S SUPERDOWN SUS SPRINGS 2013-2016. I have one more question, what are the pros and cons of having your suspension at a different height from the rear and front, because this suspension allows you to do so. http://www.rs-r.com/product/scion-fr...-springs-2013/
The owl Talon is offline   Reply With Quote
Old 12-05-2017, 11:04 AM   #20
It is a very small difference. Just balances it out visually.
Old 12-05-2017, 11:18 AM   #21
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
What's wrong with the suspension that you have now?
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 12-05-2017, 12:59 PM   #22
Gunman
Drives: 2019 Mazda Miata RF
Weight balance will shift a bit, based on the different heights. Aero balance as well, but I doubt you will ever notice it.
Gunman is offline   Reply With Quote
Old 12-05-2017, 01:34 PM   #23
Racecomp Engineering
How many miles on your OEM shocks?
- Andrew
Old 12-05-2017, 01:36 PM   #24
churchx
churchx's Avatar
Drives: 2014 GT86
Also do you really really absolutely must have that "super"down of more then inch drop? Why not a bit more reasonable drop w/o altering suspension geometry that much?
Old 12-05-2017, 05:35 PM   #25
The .4 and .2 extra drop really don’t change anything much. This is especially true for a street driven car where you are not trying to tune suspension to lose a hundredth of a second on your lap time. I bet 99.999% of the drivers on the road will not ever be able to tell the difference.
Old 12-05-2017, 07:37 PM   #26
monkeybike
Drives: 86
Very interesting.
- Andrew
Hey Racecomp,
Which of these look better to you?
It looks like they are trying to maintain the characteristics of the stock cars?
86 version
Front - 3.2kg
Rear - 4.5kg
BRZ version
Front - 3.2kg
Rear - 3.9kg
Old 12-05-2017, 08:50 PM   #27
Qadthane
Qadthane's Avatar
Drives: 2013 FR-S in Asphalt
RCE Yellows, crash/camber bolts, and a good alignment.
Keep the change and call it a day.
Qadthane is offline   Reply With Quote
The Following 2 Users Say Thank You to Qadthane For This Useful Post:
Leonardo (12-05-2017), Racecomp Engineering (12-06-2017)
Old 12-05-2017, 11:13 PM   #28
Lust
Drives: 2017 Subaru BRZ
Tein Flex Z would be a solid contender. Easy to install and offers a good range of adjustability. The benefit of going with a good coilover is that they have matched the damping and springs to provide a good quality ride. Just adding lowering springs can make the car ride and handle like junk
Lust is offline   Reply With Quote
fr-s, suspension
Search this Thread:
Advanced Search
Suspension Sale! Special Pricing for Swift, Megan, KW, HKS, BC Racing ModinJapan Brakes, Suspension, Chassis 110 11-29-2016 07:48 PM
Tein Suspension Master Catalog. Club Pricing + Free Shipping + No Tax + In Stock TAP Auto Parts Brakes, Suspension, Chassis 3 06-06-2013 05:27 AM
TEIN Suspension Products- Best pricing around- Free shipping*** Mrc@ptuning Brakes, Suspension, Chassis 8 11-16-2012 11:43 AM
Scion FR-S pricing found in website HTML?! (Update: Same as 2011 xD Pricing) WhiteFang Scion FR-S / Toyota 86 GT86 General Forum 146 03-17-2012 04:01 PM
