Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 11-26-2017, 01:08 PM   #15
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Thanks! Where is the starting point though? Do I need to loosen both and set my window level with the fixed small window and then tighten both. Also, my door is open so it's at the lowered level, do I need to remove the door connector with the switch depressed to make it set at the door closed position when setting these?
Old 11-26-2017, 01:22 PM   #16
Joon525
Joon525's Avatar
Drives: 2016 BRZ
There is no official "starting" point.
It's literally trial and error.
Set both in the middle.
Raise the window.
Open the door.
Press the sensor/switch, is it too high? The lower one or both.
Too low? Raise one or both.
Rinse and repeat.
Also...
http://www.ft86club.com/forums/showp...73&postcount=2
Joon525 is offline   Reply With Quote
Old 11-26-2017, 01:38 PM   #17
B-R-Z
B-R-Z's Avatar
Something is messed up. I pulled the plug out of the window controls while having the switch depressed so I can set it at closed height. I figured it was easier this way so I could line it up with the fixed window.
Now my window is stuck wide open and the control does nothing though I can hear the motor working (it will not raise). Is there a memory module I can reset?
Edit: Found a video for resetting this.
Old 11-26-2017, 02:43 PM   #18
B-R-Z
B-R-Z's Avatar
Done and everything looks close enough for me. The part I didn't get about these adjustments were that #1 and #2 were stoppers that make the window stop. I thought they were attached to the glass which is why I was confused about setting a starting point or whatever.
Pictured below is the window from my first post that was set way too high. It is now just a hair over the fixed small window which I think is ok to give it a snug fit when closed. On the drivers side which was not nearly as bad, the bolt is pretty much off the charts so I am guessing they adjusted something else that threw this off? I am going to tell them to not touch it, the last thing I want is them in there fiddling and breaking something else.
Thanks again, @Joon525
Old 11-26-2017, 04:22 PM   #19
Joon525
Joon525's Avatar
Drives: 2016 BRZ
No problem.
Sorry for the short answers but I had limited time to get my own work done. Glad to see you're on your way to getting things back to where they should be.
Good luck with the body shop.
Drivers window switch flashing - does nothing? STS-V Issues | Warranty | Recalls / TSB 4 08-11-2014 09:42 AM
There is a new window switch available to fix the passenger auto up/down issue Subie Issues | Warranty | Recalls / TSB 51 04-13-2014 03:34 PM
Window Switch accent review from 86_zn6 BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 0 09-10-2013 12:13 PM
Anyone have this window switch accent? BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 8 08-20-2013 05:29 PM
Window switch lights? Narcoden Scion FR-S / Toyota 86 GT86 General Forum 4 05-01-2013 08:17 PM
