Old 01-11-2018, 03:30 PM   #15
neilr
Drives: 2018 Cayman, 2013 FR-S
Originally Posted by gtengr View Post
Yeah I wish they had kept that leveling knob. By no active adjustment I mean it doesn't turn the lights with the steering wheel or make any other compensations after taking its initial set.
Maybe I misunderstood what you originally said. Do your lights never change once you're moving?
Mine move vertically, but their responsiveness is awful. When I start up a hill, the lights are pointed too high up, into the eyes of oncoming traffic. If the hill is long enough, they will eventually point back toward the ground. If the road undulates, the lights are quick to point up and slow to point down, so I'm left blinding other drivers until I reach level ground.
neilr is offline   Reply With Quote
Old 01-11-2018, 04:22 PM   #16
gtengr
Drives: 2017 BRZ
Interesting. I haven't noticed them adjusting like that. I could always tell on my M3.
gtengr is offline   Reply With Quote
Old 01-11-2018, 05:23 PM   #17
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Link? That video is for aftermarket lights - is there something similar on the stock lights? If it stops raining, I'll actually poke around under my hood this weekend. :-)
What do you mean by no active adjustments? Apparently the pre-2017s had an adjustment knob in the cabin next to the interior light brightness knob. Bit of a shame they switched.
There is an 8mm knob on the back of both headlights that enables you to raise/lower the headlights.
mjanmohammad is offline   Reply With Quote
Old 01-11-2018, 09:45 PM   #18
neilr
Have you seen this knob on a 2017, or are you referring to the video in this post? More to the point, does that knob have any effect on the auto leveling?
Old 01-11-2018, 09:46 PM   #19
mjanmohammad
I’ve used it to adjust the headlights on my 2017 BRZ after I lowered it and installed new RLCA
Old 01-11-2018, 09:49 PM   #20
neilr
I'm not sure if my 2er leveled the lights while I was driving, but you could see the adjustment when starting the car. It did track horizontally when you turned the steering wheel, which was nice. :-)
Update: I've been paying more attention to the behavior of my lights and I was mistaken: they are not adjusting while I drive - I only thought they were. I'm chalking it up to road variations.
Last edited by neilr; 01-15-2018 at 01:05 AM. Reason: Update with later observations
Old 01-11-2018, 09:50 PM   #21
neilr
I'll check it out.
Old 01-15-2018, 01:12 AM   #22
neilr
Name:  BRZ Headlight Adjustment - Driver's Side.jpeg
The weather was cooperative, so I looked at the back of the headlight and there is an 8mm hex adjustment knob. Now I need to find a place to do the adjustment.
BTW, I stopped into my nearby Subaru service department and three different people assured me that my lights are aimed correctly. Unfortunately, that does nothing to mitigate the people flashing me at night.
The Following User Says Thank You to neilr For This Useful Post:
gtengr (01-15-2018)
Old 01-15-2018, 10:32 AM   #23
mjanmohammad
Attachment 161975
I just did it in my garage/driveway. They're flat so I backed the car out and leveled the headlights against the back wall of the garage. Took 10 minutes.
If you don't have a flat garage, a parking lot near a wall will also work. 20 feet away, adjust your beams to be the same height as the headlight on the wall.
http://www.jwspeaker.com/blog/how-to...am-headlights/
Old 01-15-2018, 11:28 AM   #24
gtengr
Drives: 2017 BRZ
I'm just going to mark the adjuster nut with a sharpie and adjust downward in 1/4 turn increments (or 1/8's if needed) until I like it.
Old 01-15-2018, 11:43 PM   #25
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
For anyone considering rear control arms, the SPC version has the holes required to relocate the sensor.
tehShirt is offline   Reply With Quote
Old 01-17-2018, 03:50 PM   #26
neilr
I adjusted my driver's side light last night. With the wrench I was using, I could only turn the knob 90 degrees (at most) before reseating it. I'm pretty sure it took at least 2 full rotations of the knob to get the projection moved to an appropriate height.
I can report that no one flashed me on my drive home, so I'm calling it solved. Thanks to @mjanmohammad for pointing out the knob on the OEM lights.
The Following 3 Users Say Thank You to neilr For This Useful Post:
gtengr (01-17-2018), mjanmohammad (01-17-2018), SCFD (11-08-2020)
Old 01-17-2018, 04:46 PM   #27
gtengr
Drives: 2017 BRZ
Thanks for the update. I haven't driven mine in several days so I have yet to adjust, but I will follow your rec.
Old 01-17-2018, 04:48 PM   #28
mjanmohammad
@gtengr a ratcheting 8mm wrench (not the socket) will make the task much faster.
The Following User Says Thank You to mjanmohammad For This Useful Post:
gtengr (01-17-2018)
CAUTION: 2017 REAR CAMBER ARM PROBLEM with Performance Package 007BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 01-11-2021 05:24 PM
Has anyone ACTUALLY driven their car without the headlight leveling sensor? Var Cosmetic Modification (Interior/Exterior/Lighting) 11 12-27-2017 11:39 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
Auto Headlight Sensor Conector Help!!! kmbkk BRZ First-Gen (2012+) -- General Topics 5 06-04-2013 10:43 AM
