#15 |
Wes
I got the Meisterrs and have no complaints. Relatively inexpensive, decent quality, OEM like ride characteristics and improved handling
#16 | |
Drives: '15 BRZ RA
#17 | |
Not a troll
#18 |
Drives: '15 BRZ RA
One advantage is that you can store a bigger capacity of oil. It'll take more time to over-heat and your suspension will not feel dead after some time. It is not only how fast you can go, but also for how long ...
#19 |
Not a troll
#20 | |
- Andrew |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | churchx (11-20-2017), strat61caster (11-20-2017) |
#21 | |
Adjustablity is nice, but I think people overestimate how often they'll use that adjustment. Good valving, even on the track, is not harsh. Yes, a very track focused coilover is not ideal on the street, but it's not far off. A lot of the lower end cheap coilovers are adjustable because they use the same damper cartridge for multiple vehicles. They don't dial in the valving beyond getting it in the range and then letting the user find the spot that "works" with the adjuster. Same reason they are often dual height adjustable...one damper cartridge for multiple cars and then different lower/upper mounts. With a lot of adjustable coilovers, the adjustment isn't very good. It's often non-linear from click to click, with minimal difference between click 4 and 5 but a huge difference from 5 to 6. Or they have a huge effect on high piston speed damping with only a mild effect on low speed (which is where the majority of the effect on handling happens). The stiffest settings on a lot of lower end coilovers are trash. Some might be faster with them turned up, but that's because the soft/medium settings are waaay too soft in the low piston speed range. So in essence, at soft they can ride okay, but handle like garbage...while at stiff, they can handle okay (on a smooth surface) but ride like garbage. This doesn't mean it's a good adjustable shock, it means it's a shock that isn't dialed in right. A good shock can ride and handle really well at the same time. You don't necessarily need adjustability to get that, but you do need a shock that's been dialed in well with sufficient low speed and not excessive high speed piston damping. Adjustability is excellent for track day and autocrossers who need to dial in handling with a little more fine tuning (and for fine tuning you need a shock that is consistent in it's adjustment). It's also good if you plan on changing spring rates slightly, or if you encounter rain or different track surfaces. It can be nice to have for a street driven car to fine tune ride and make the car a little less aggressive than it would be at the track. - Andrew |
| The Following 8 Users Say Thank You to Racecomp Engineering For This Useful Post: | churchx (11-20-2017), DarkSunrise (11-20-2017), JazzleSAURUS (11-20-2017), nikitopo (11-20-2017), strat61caster (11-20-2017), Tcoat (11-20-2017), Teseo (11-20-2017), x808drifter (11-20-2017) |
#22 |
Drives: '15 BRZ RA
#23 |
Lots of people claim autox setup is different without much autox experience. I concur with church and racecomp, a fast setup shouldn't be teeth rattling because that means the tires aren't gripping well.
Stiffening up the dampers is a weak replacement for not having enough spring or a psychological confidence booster, I doubt it's actually faster that way. Edit: and yes, b6/8 are most definitely monotube, Google it. Last edited by strat61caster; 11-20-2017 at 01:24 PM. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Racecomp Engineering (11-20-2017) |
#24 |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | nikitopo (11-20-2017), strat61caster (11-20-2017) |
#25 | |
Drives: '15 BRZ RA
Yes cheap coilovers might be in many cases worse, but let's not compare apples with oranges. Adjustability in a good suspension makes a difference. |
#26 | |
- Andrew |
#27 |
Drives: 2014 GT86
nikitopo: but with preset budget of purchase for customer or preset budget/profit margin for manufacturer one has to compare apples to oranges. Just like with hifi HW, where i'd prefer higher quality stereo over multichannel audio setup, i'd prefer higher quality/dampening coilovers that cost as much as ones, where part of budget was spent for "adding knobs", and for main function - measly leftovers. At least for lowend, where that budget is scarce to begin with. Everyone wants to get best available for the money, right? And where is petition for penskes at flex Z price to sign under?
| The Following User Says Thank You to churchx For This Useful Post: | Racecomp Engineering (11-20-2017) |
#28 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
If you don't mind importing from Australia, Shockworks and MCA both make great coilovers that provide a good balance for road and track applications.
| Im buying coil overs within the next 2 days i need help deciding what coil overs | Anthony7515 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 06-30-2014 09:47 AM |
| Im buying coil overs within the next 2 days i need help deciding what coil overs to | Anthony7515 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 06-27-2014 02:00 PM |
| Scion FR-S options:what options did you have dealer installed? | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 01-06-2014 02:35 AM |
| Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 01:53 PM |
