#15 |
Drives: BRZ. R34 GT-T
Good find!
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
#16 |
Drives: 2013 FRS- Hot Lava
Mechanical engineer trying to get into some aesthetic only work with carbon fiber. What kind of resin (trying to be as budget friendly as possible here, as I'm about 100% sure I'll be screwing these up) do you guys recommend? Other than the actual carbon sheets and resin, is there anything else that's necessary?
#17 | |
I use the resin this guy uses in his vid here. I'll grab the name for you later this eve. Learning carbon is a hell of a bumpy road in my experience. I screwed up a lot and any small mishap can ruin hours upon hours of work. its all about being prepared and prompt and never take shortcuts. Nothing can substitute hard elbow grease and many hours of sanding and prep. Im not expert but heres some tricks and tools I like. A nice big portable LED light- to check imperfections, bubbles, or anything stuck in the resin. Heat gun- for helping remove bubbles. Foam brushes- I use foam brushes because I've lost many a bristle in my resin that are sometimes hard to spot and aggravating when eventually found under 3 coats of resin and clear. Spray on adhesive- much simpler process to adhere carbon to part. Heres a trick as well, spray the entire back of your piece of carbon before you stick it on your part with spray-on adhesive and let it dry. It will lock the fibers/weave in place so you dont accidentally mess it up when overlaying. This was a game changer for me. Spray your part black before you overlay (this is a must). When you are wet sanding- pay attention to the color of the water coming off the part, if its white, your sanding just the resin which is good. If it turns grey, you have sanded through the resin and are sanding the carbon which will mess the finish up greatly. I'll think of more in a bit and update. I'm overlaying my center console right now which has been fun. Investing in a vacuum bagging set up will greatly improve your results if your parts are complex in shape. Highly recommend.
| The Following User Says Thank You to olsonpg For This Useful Post: | Imrac (11-13-2017) |
#18 | ||
![]() Quote:
Spot on again with the prep work. I will spend all day doing prep work if I have to. It's the difference between it coming out wavy or nice and smooth, and also getting a good bond. Heat is nice, but be sure to follow resin manufacturer's specs on heat. If you have a wet/runny resin heat can cause it to run and possibly come out lean. Plus resin is a chemical reaction with heat as a byproduct. If you heat it too much it can exotherm and ruin the layup. I usually let the resin kick a little to thicken up before applying heat. Vacuum bagging def. makes it easier, but I've had great results on some funky ass parts at work just doing a wet layup, lay down some peel ply or perforated ply, and using a brush to push out air bubbles. Couldn't tell the difference unless you looked very close with a bright light! Couple questions? Why would you use spray adhesive instead of laying up and bonding directly to the part? Does carbon not bond well to plastic? Do you put a boundary layer between the part with release agent and pop it off after it cures, then use adhesive to bond? And why do you spray the part black? So you don't get color showing through the fibers? |
#19 | |
Your peel ply method is intriguing. do you lay down the peel ply so you can really massage the carbon onto the part or is it strictly to get the bubbles out. I'd love to learn how this is done. And yeah, if your only putting one layer of fiber over your part you'll usually get areas where the part can be seen between the weave. If its a dark color or black it all blends in but if its white you'll most def see it. It will look like little white dots all over the place. I think the only reason I use spray adhesive is convenience. I mainly do interior parts so I really dont need a tough chemical bond between the carbon and the part. The spray on adhesive and then well saturating the carbon has always been more than enough to keep the carbon well secured. Aesthetic carbon work has kicked my ass for years, but I refuse to give up until I've mastered it. I'm thinking about investing into an infusion process. It seems to be what most people have settled on when looking to achieve consistent aesthetic parts.
#20 | |
#21 |
Drives: GTS 86
Adhesive spray will fail at above 50 degrees celsius. The problem is in the summer inside you will reach that temp in no time...so the carbon will start de laminating. I recommend using the resin as bonding agent between cf and the part.
I use spray only when i lay the carbon in the mold! |
| The Following User Says Thank You to Hawk77FT For This Useful Post: | drz400dude (11-17-2017) |
| Tags |
| carbon, carbon fiber, resin |
| FS: carbon fiber Password JDM side skirts and carbon fiber 3 pce BRZ front splitter | protpibe | Canada Classifieds | 9 | 02-07-2016 10:37 PM |
| Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! | F-T | Exterior Parts - The Rest | 285 | 08-24-2015 05:42 PM |
| Vis racing ams carbon fiber trunk and Seibon carbon fiber diffuser | Mr.Frs | Cosmetic Modification (Interior/Exterior/Lighting) | 36 | 04-08-2015 11:51 AM |
| Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) | master345 | Cosmetic Modification (Interior/Exterior/Lighting) | 56 | 05-04-2014 12:10 PM |
| FS: Pair of Carbon fiber mirrors cover and a pair of real carbon fiber side fin | FRSToyota86 | Canada Classifieds | 3 | 03-19-2014 02:07 AM |
