#155 |
Drives: 2015 CWP Limited BRZ
This is an awesome build. What was your swap budget if you don't mind me asking? I tried looking on your thread and I couldn't find it. I must've missed it if you did mention it in here.
addictedcollectibles.r/My IG
'86 E30 (Project) 'VARIS Widebody http://www.ft86club.com/forums/showthread.php?t=103676 |
#156 | |
Drives: 2017 WR BLUE BRZ
#157 |
Have you considered removing the front grill and getting a "drift armor" bar to increase front airflow?
#158 | |
The fan shroud kit I have comes with 900 cfm spal fans. Spal makes the same fan with a larger motor that moves 1300 cfm, Spal also makes an 1800 cfm fan that has a slightly larger foot print. I ordered two of each to see if I could fit two of the big ones or maybe one big one and a smaller one, or just both smaller ones. The cooling needs some help dealing with stop and go traffic type driving. |
#159 | |
#160 |
#162 |
I’ll leave this here. |
| The Following 4 Users Say Thank You to ILLSMOQ For This Useful Post: |
#163 |
Engine was heating up during extended aggressive backroads driving on 90 degree+ days. Worked on some ducting to get more air through the radiator.
Had the engine cooler mounted to the factory crash bar. ![]() Cut out the crash bar ![]() Built the ducting out of home depot aluminum sheet. ![]() ![]() ![]() ![]() ![]() ![]() Opened up the grill a bit ![]() Mounted the cooler further back ![]() ![]() Sealed it all up with foil tape
| The Following 6 Users Say Thank You to ILLSMOQ For This Useful Post: | civicdrivr (11-19-2018), Code Monkey (10-16-2018), Joesurf79 (10-28-2018), Sportsguy83 (10-17-2018), surfwaxsmitty (12-14-2018), wooly35 (11-16-2018) |
#164 |
Tried drifting...didn’t work out so good. Not as easy as I thought it would be.
#165 |
Drives: seat ibiza
Awesome build!
I understand you also drive it on the streets. Does the fuel gauge work with the motec unit? And do you know your mpg? Is it better than 13? |
| The Following User Says Thank You to karlsson For This Useful Post: | ILLSMOQ (01-16-2019) |
#166 |
#167 | |
I Love custom Turbo kits
Drives: Limited BRZ
I am getting 13ish MPG (LS2 with heads/cam), but getting tuned in two days, looking forward to increasing it.
#168 | |
Drives: LS Swapped Scion FRS = 440HP
| Pure Automotive's MoTeC Plug and Play V8 Swap Thread | Pure Automotive | Engine Swaps | 51 | 11-25-2017 12:10 PM |
| Pure Automotive's 2017 Race and Show Schedule | Pure Automotive | Mid-Atlantic | 4 | 01-21-2017 01:07 PM |
| Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! | Pure Automotive | Member's Car Journals | 53 | 03-05-2015 07:11 PM |
| Pure automotive pre meet | KslayFRZ | Mid-Atlantic | 0 | 07-19-2013 12:32 PM |
| Anybody want to help me pick up my car at Pure Automotive? | TyperRspec789 | Mid-Atlantic | 4 | 01-31-2013 03:07 PM |
