86WORX
Old 11-10-2017, 10:58 AM   #43
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Originally Posted by D_Thissen View Post
Are you saying that his butt dyno is incorrect??
It's like when people move from a TD04 to a VF in EJ subaru land. "It feels slow when I drive around town."
Did you, idk, actually let the turbo spool?
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following 2 Users Say Thank You to JazzleSAURUS For This Useful Post:
Cole (11-10-2017), D_Thissen (11-10-2017)
Old 11-10-2017, 11:52 AM   #44
fika84
fika84's Avatar
ITBs are good and all, but when are we going to get variable length runners?
velox was also working on a few different intake manifold designs. They didn't get the gains they wanted for NA if I remember correctly, but saw some good gains with FI..
http://www.ft86club.com/forums/showthread.php?t=82479
fika84 is offline   Reply With Quote
The Following 2 Users Say Thank You to fika84 For This Useful Post:
Spuds (11-10-2017), Tokay444 (11-10-2017)
Old 11-10-2017, 12:29 PM   #45
AxisPower
Drives: 23 GT4RS
Curious to see the results. Kind of lame though they're charging 2k+ for a kit that uses 20 year old 20v 4age itbs that were originally for a 1.6l motor.
AxisPower is offline   Reply With Quote
The Following 3 Users Say Thank You to AxisPower For This Useful Post:
chaoskaze (11-11-2017), fika84 (11-10-2017), Tokay444 (11-10-2017)
Old 11-10-2017, 12:44 PM   #46
fika84
fika84's Avatar
RIGHT?!?? I'll wait another year or 2 to see what comes of it. Not going to be building the motor anytime soon. Also always have to wait for @celek to make the mistakes and learn first so we can benefit from it
Old 11-10-2017, 01:56 PM   #47
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
You have patience ... How many years is he working on this? lol
Old 11-10-2017, 01:58 PM   #48
fika84
fika84's Avatar
Lots and lots. This platform is fucking expensive though!!
He's going a bit further than I'm going to go.. but it's good to stretch the boundaries!
celek (12-04-2017), nikitopo (11-10-2017)
Old 11-10-2017, 04:27 PM   #49
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by venturaII View Post
And cylinder layout has absolutely zero to do with it.
True, not directly.
I meant more as in the fact that since the engine layouts alone are so different it would make everything else down the line very different as well.
Compounding the issue with trying to compare them as if they were "apples to apples"
Head design would have been a better thing to bring up.
Trying to justify that ITB's would be the same on our car because the RB26 has them, would be like saying oh that mustang makes a ton more low end with that cross pipe. I should do the same on my civic.
The Following User Says Thank You to x808drifter For This Useful Post:
Old 11-10-2017, 04:37 PM   #50
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by x808drifter View Post
True, not directly.
And the problem is that no one bothered to read my original post about this correctly.
The statement I was replying to initially talked about going above 8500RPMs to see any gains. I pointed out the RB26 had ITBs and the RPM limit was much lower, similar to our engines.
Then the rest of the responses was a bunch of noise about engine layout, boost, and other stuff.
My point is and always will be, you can still see benefits of an ITB setup in our engine with the redline intact. Whether these gains (below 7500RPM) are enough for your setup or if you're just wasting money is entirely at your discretion.
But yes, keep thinking I'm equating a 30-year old engine with the FA20.
Old 11-10-2017, 04:50 PM   #51
Tokay444
Anti stance.
Tokay444's Avatar
What you failed to point out was that the RB26 has boost.
Apples to oranges.
And how much of the "Gains" can be attributed to the ITBs on the RB26? The engine was only ever offered with ITBs, so there are no "gains" to speak of.
What would be more beneficial to the topic is, if you would highlight the benefits of an ITB setup on an NA 4 cylinder, below 7500 RPM.
Old 11-10-2017, 05:26 PM   #52
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
Apples to oranges.
Can you just move on and stop ruining a thread with a argument? ITB's have been ran on various NA cars for decades and the benefits are known. No one puts them on a NA 4 cylinder expecting power. The sole reason for them existing is THROTTLE RESPONSE.
There now please do us all a favor and stop commenting
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
The Following 2 Users Say Thank You to Detroiter For This Useful Post:
Tokay444 (11-10-2017), Williampreza (11-15-2017)
Old 11-10-2017, 05:47 PM   #53
mav1178
mav1178's Avatar
Don't forget the sound. If an ITB setup can make the FA20 sound better (i.e. 4AG w/ 20V ITB) then it's a worthwhile mod, especially with the right intake to maximize the sound.
The Following 5 Users Say Thank You to mav1178 For This Useful Post:
CSG Mike (11-11-2017), Detroiter (11-10-2017), Shark_Bait88 (11-10-2017), Teseo (11-10-2017), wparsons (11-15-2017)
Old 11-10-2017, 06:18 PM   #54
Tokay444
Anti stance.
Tokay444's Avatar
Sure, as long as we can agree that the analogy of, ”it works in this completely different set of parameters so it should work just fine here.” was a stupid analogy to make.
Old 11-10-2017, 07:43 PM   #55
Kicknwing
Drives: 2014 frs
i mean they have only been used in cars both street and track for years. So i see no reason why they wont work on here. also don't see why greddy and sard would invest thousands on r&d for something that wont work. they would never see there return
Kicknwing is offline   Reply With Quote
Old 11-10-2017, 07:48 PM   #56
mav1178
mav1178's Avatar
We can also agree comments like "inb4 no gains" are stupid comments to make.
There, you and I are one and the same.
Search this Thread:
Advanced Search
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 01:20 PM
SARD CF Intake Pipe, SARD Oil Catch Can, TRD Oil Cap, Rad Cap, Battery Clamp Trojan_SC Engine, Exhaust, Bolt-Ons 19 03-28-2018 08:52 PM
Bad news good news ls1ac BRZ First-Gen (2012+) -- General Topics 2 10-01-2016 10:11 PM
SARD 86 GT1 Body Kit + SARD LSR Wing nigel-jdmparts Cosmetic Modification (Interior/Exterior/Lighting) 1 04-27-2015 01:41 PM
