#15 |
Drives: FR-S Whiteout
RS-3 V1, RSR, and now RSRR. I suppose both these brands run a bit wide.
Intent > Content
cowardice is the mother of cruelty. |
#16 |
Drives: 2013 satin white brz limited
#17 |
Drives: 2015 FRS
I ran MPSS 245/40/17 on 17x8 wheels and they fit perfect. I wouldn't go anywhere below 245 on 9" wheels unless a specific tire is well known for running wide.
Sent from my HTC 10 using Tapatalk |
#18 |
Drives: Evo X FE/FRS 10 Series
It really depends on the tire. These are 235/45/17 Federal FZ201s on 17x9 57CRs. They run really large and measure out to almost a 250.
#19 |
Drives: 2015 Lightning Red BRZ
I have 17x9s with mpss 245/40/r17s. Tire fit the rims well, but I did need spacers up front to prevent rubbing on the suspension. Love the setup, noticeably better grip.
Sent from my SM-J700T using Tapatalk |
#20 | |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
I pick up my MPSS 245/40/17 on Saturday on the Rota Titan 17/9 E42 and hope I don't need my 5mm spacers? Guess I find out soon enough |
#21 |
#22 | |
PS4 's are currently available in 18, 19 or 20" here in the states |
#23 |
Drives: rocketship
Naa.. still on the stockies.. running federal 595 in 225/45 17. These are my fall /winter tires.
the 17x9 setup will be for summer, most likely with the continental ECS.
#24 |
That ended up being a waste of time, Costco would not install the tires as I would have needed my spacer to clear the front strut. They did refund my purchase in full
#25 |
Drives: rocketship
Trying to decide on the Continental extreme contact sports.
which would work better on a 17x9 wheel? 245/40 or 255/40?
#27 | |
Proud of BOXER
Drives: Subaru Boxer
That's bs because I ran 17x9 +42 et up front with 245/40/17 for several years without any rubbing.
Maybe you already have negative camber up front via camber bolts though, that would cause the tire to be closer to the spring perch.
#28 |
Drives: '97 NSX-T, '18 Type R
Michelin run wider than some tires. I know the AS3+ was almost an inch wider than the Pirelli P Zero AS tires my son just put on his 17 x 9 Apex rims. Both tires were 245/40R17. He isn't rubbing either even lowered on RCE Yellows and with -.8 chamber in front.
| Best tire size for 17x9 wheels | Elliotw | Tracking / Autocross / HPDE / Drifting | 3 | 09-30-2017 02:22 AM |
| Good Tire size for 17x9? | J-Money | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-05-2016 09:30 AM |
| Replace Only 1 Tire? / Spare Tire Question | chermo12 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 07-28-2015 02:44 PM |
| Nubby wheel/tire/fitment guy in need of advice 17x9+35 | KevinK121 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 07-17-2015 08:34 AM |
| The rite tire size? rpf1 17x9 +45 | Gillams | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 39 | 04-22-2015 01:37 PM |
