#127 |
Drives: '15 BRZ RA
There were corrective actions in '14 with bigger length intake & exhaust valves and changed cams and cam gears. This was found accidentally by a mechanic who was building an older engine and the new valves were not fitting and by myself independently while doing a complete comparison of part numbers. These changes provided a bit more aggresive timing and a gain of about 5-6whp. Cars of similar mileage on same dyno were giving this difference depending the manufacture year (pre- or post-change date). Strangely enough, these engines were not re-spec'd and never re-registered in the countries based on the changed internals. Your argument that companies are not allowed to do whatever they want is not always valid and history shows that there are still gray areas.
I am sure that Porsche cars have similar stories to share ... |
#128 | |
#129 | |
Anti stance.
#130 | |
You are still relying upon dyno readings which are meaningless.
#131 |
#132 |
Drives: '12 C63 P31, '17 GTI Sport, '00 MR2
Porsche loves to make mid model year changes all the time. Whenever I order parts online I have to enter the VIN # to guarantee that what I'm buying will fit.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
| The Following User Says Thank You to WolfpackS2k For This Useful Post: | Tcoat (11-06-2017) |
#133 | |
There are a couple of people that truly believe that by bolting one or two 17 parts on their pre 17 they will get huge gains. So it is important that they convince everybody that the gains are actually there to be had.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | funwheeldrive (11-06-2017), Tokay444 (11-06-2017) |
#134 |
Drives: '23 BRZ
https://www.caranddriver.com/reviews...al-test-review
A Lot of Work for a 0.1-Second Gain Predictably, a 5-hp gain and marginally shorter gearing do little to improve measured performance. Our 2017 test car hit 60 mph in 6.2 seconds and covered the quarter-mile in 14.8 seconds—improvements of 0.1 second across the board relative to the last manual BRZ we tested, a 2016 model. Trap speed remained the same at 95 mph. |
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | funwheeldrive (11-06-2017), Tokay444 (11-06-2017) |
#135 | |
Only users lose drugs.
Drives: All the time
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#136 | |
![]() Moto-East dyno'd their BRZ at 175 whp stock: ![]() And Edmunds dyno'd their FR-S at 173 whp stock (on CA 91 octane):
2022 BRZ Build 2013 FR-S Build |
| The Following 2 Users Say Thank You to DarkSunrise For This Useful Post: | funwheeldrive (11-06-2017), Tcoat (11-07-2017) |
#137 |
Drives: '15 BRZ RA
The valves were changed at 2013.5 for the MY14 cars. At first we found that these parts had different numbers and Tcoat insisted that there was no actual change and manufacturers/vendors constantly changing numbers. Then there was a comparison and the length was actual different. Everything is documented.
#138 | |
Drives: '15 BRZ RA
I still believe that Cayman is a much better car than a 86/BRZ. If I was to buy another sports car, for sure it would be one of the candidates |
#139 | |
"Could be as simple as a supplier change or as advanced as a correction for a known issue or anything in between. Unfortunately we will not likely ever get a true answer to that question (there will be loads of speculation that people think is true though) At work we can have a different part number on a part because the coating thickness spec changed by 2 microns." Assuming that parts have changed based strictly on the numbers is a fools game. NEWSFLASH - Parts also change and the number stays the same. That isn't even getting into the world of acceptable tolerance variations. All that is "documented" is your opinion and speculation. Even the guy that actually had come up against the changes got fed up with your theories being presented as facts: "Alright so at the end of all this post what did we all learn...... 1. At the end of production year 2013 Subaru increased the intake valve length to what it is on todays engines. Which I posted about a year ago..... 2.Internet software by Subaru has the same numbers as the disk version..... 3. Everyone who read this thread has lost 10 minutes of their life they will never get back................ ![]() Look this is over, you started this thread stating almost every valve train part is revised in 2015. That is FALSE 100% FALSE!!!! I covered this a year ago, the change with adding the length to the intake valve happened in production 2014 Which means the valves were actually swapped in 2013 no major changes since...... The head number changed because they are assembled with the longer valves and supporting hardware. I'm not going to debate this any longer. IF you want to believe you have a super motor go ahead makes no difference to me... " http://www.ft86club.com/forums/showthread.php?t=84282
#140 | |
| BRZ vs Cayman/Corvette | Norcalkid | FR-S / BRZ vs.... | 128 | 01-31-2017 01:36 PM |
| Twins vs Cayman/Boxster 211 | botbs | FR-S / BRZ vs.... | 15 | 10-06-2014 11:09 AM |
| 2013 981 Cayman | ironchef | Other Vehicles & General Automotive Discussions | 49 | 12-09-2012 08:03 PM |
| FR-S vs Cayman | colganc | FR-S / BRZ vs.... | 102 | 09-13-2012 05:17 PM |
| GT86 vs. 370 vs. Cayman S | wrxgoose | FR-S / BRZ vs.... | 0 | 08-28-2012 12:26 AM |
