Old 10-10-2017, 07:10 PM   #15
FirstWinter
Drives: Car
Should've showed the full capabilities of the CSG FLA with the airborne pic
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
whataboutbob (10-14-2017)
Old 10-10-2017, 07:19 PM   #16
Old 10-10-2017, 07:21 PM   #17
FirstWinter
Drives: Car
CSG spec gives you wings
Old 10-10-2017, 07:21 PM   #18
Bonus pic. Testing on R-comps.
FirstWinter (10-10-2017)
Old 10-10-2017, 07:23 PM   #19
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Management sees where the CSG funds have been budgeted towards as of late. Management is pleased. Management give pat on back.
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
Old 10-10-2017, 08:15 PM   #20
strat61caster
strat61caster's Avatar
That says it better than I can.
Still 6k F/R?
ineedyourdiddly
Old 10-10-2017, 09:57 PM   #21
Still 6k F/R?
Yes, +-2kg/mm optional
strat61caster (10-11-2017)
Old 10-11-2017, 06:23 AM   #22
churchx
churchx's Avatar
Drives: 2014 GT86
Originally Posted by Cchmelir View Post
Maybe I worded it wrong. I care more about the performance than it being really low. Basically what I want is as low as I can go without compromising performance.
Generic consensus is to keep lowering IIRC within reasonable 1", eg. 20mm and alike. Our cars even stock are already relatively low/have relatively low ground clearance/relatively short shock travel (especially in rear). As bonus with such reasonable drop you also won't need load of other parts to fix messed up geometry and other issues that may stem from too low (eg. extra wear of bearings / thus need for diff riser). For shocks to be able to do their job to dampen road irregularities, or eg. on track when/if you hit kerb and so on .. they need some actual travel, not riding on bumpstops. And going lower means also going stiffer springs. So daily driving comfort also can be compromised, if it's dual-use car, if you'll over-lower car. So basically keep it reasonable, and you'll keep your performance, comfort, steep driveways & roadbumps compliance and there are several relatively good coilover options at low-middle budget too. Tein Flex A&Z, RCE Tarmac 0, Koni yellows or Billstein B6/B8 with stock or RCE yellow springs, to name few.
P.S. I suggest for track performance to get something for better performance alignment. Eg. camberbolts for front, adjustable rear LCA, as stock our cars have only toe adjustment, but there is much grip & better tire wear to be had from more static camber on track. Actually imho extra camber vs stock alignment may net faster cornering speeds then what coilovers may improve.
The Following 3 Users Say Thank You to churchx For This Useful Post:
Captain Snooze (10-14-2017), Clipdat (10-13-2017), Teseo (10-11-2017)
Old 10-13-2017, 04:10 PM   #23
BayBRZ
Drives: Subaru BRZ
What spring rate for the CSG Spec A's do you think would be well matched for a Spirited DD and very rare occasional track car?
17x9 245s with MPSS/S04s or some sticky street tire, and FI if that matters
'16 SWP BRZ
BayBRZ is offline   Reply With Quote
Old 10-13-2017, 04:55 PM   #24
Stick with the 6k.
Old 10-14-2017, 04:00 AM   #25
Apex No.525300887039
Drives: 2016 Scion FRS
Stick with the 6k.
What are the recommended spring rates, comfort be damned, if I'm after the most neutral balance on track as possible?
Apex No.525300887039 is offline   Reply With Quote
Old 10-14-2017, 04:09 AM   #26
That depends on what else you have done to your car.
Old 10-14-2017, 12:20 PM   #27
direction with the car at the moment will be standard bolt on exhaust + coilover + 200TW tires, with the rest oem, no real aero yet
Old 10-14-2017, 01:17 PM   #28
Need either end goal, or "at the moment". You can only tune for one or the other, unless you want to severely compromise one or the other.
Based on your post, I'd say stick with the supplied 6/6, and then order more springs if you want a change.
strat61caster (10-15-2017)
coilovers, suspension
Need help picking coilovers Cchmelir Brakes, Suspension, Chassis 5 10-11-2017 02:33 PM
Picking up a 86, or maybe not... andyzpandy Scion FR-S / Toyota 86 GT86 General Forum 24 05-12-2015 05:04 AM
A little help picking a set up.... wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 11-18-2014 07:41 PM
Picking her up at 5! remorse87 Scion FR-S / Toyota 86 GT86 General Forum 14 10-07-2012 11:51 AM
