Old 10-10-2017, 05:09 PM   #1
Cchmelir
Drives: Subaru BRZ
Help with picking coilovers
Hey guys, just got a 2014 BRZ so new to this forum and need a little help picking coilovers. I DD the car (about 100 miles round trip to Work and back) and I plan to do some autocross with the car (not too much just about 4-6 times a year). I want some good quality coilovers but I am on a little bit of a budget. I would like to lower the car a little more than most of you would probably approve of also. I know it will take some of the performance away and I will probally get a ton of crap for this but I really like the look of a low car. So are there coilovers out there that are in the price range of about $1,500 USD that can give me the low I want with still a decent performance for track days?
Appreciate it guys!
Cchmelir is offline   Reply With Quote
Old 10-10-2017, 05:29 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
"want decent performance for track days" and "lower the car more then most would approve"? Imho those bits are exclusive. You don't care about handling and just overlower car for arguable looks, or you care about handling/performance and don't make suspension close to unable to do it's job. +If you lower car to unreasonable extent, you need more spendings to offset all the wrongdoings to suspension/geometry. LCAs or topmounts better fit for lowering that would leave at least some shock travel, roll center adjustment kits, diff riser and so on. "Quality coilovers" bought for sum that left off after deducting cost of these parts & work to install them? LOL
The Following 3 Users Say Thank You to churchx For This Useful Post:
Shark_Bait88 (10-10-2017), x808drifter (10-10-2017), Yardjass (10-11-2017)
Old 10-10-2017, 05:42 PM   #3
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
Low
Performance
Cheap
Pick 2
G-Man is offline   Reply With Quote
The Following 3 Users Say Thank You to G-Man For This Useful Post:
N8RH8R (10-11-2017), smg1138 (10-10-2017), Teseo (10-10-2017)
Old 10-10-2017, 05:46 PM   #4
Cchmelir
Drives: Subaru BRZ
Maybe I worded it wrong. I care more about the performance than it being really low. Basically what I want is as low as I can go without compromising performance.
Old 10-10-2017, 05:53 PM   #5
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
I think the CSG spec Tein Flex A are a good fit. I’ll be considering those when I’m ready for coils
Barefootdan is offline   Reply With Quote
Old 10-10-2017, 06:12 PM   #6
FirstWinter
Drives: Car
The CSG spec Tein Flex A are right in your budget and fit your needs. CSG is taking pre-orders for them currently.
FirstWinter is offline   Reply With Quote
Old 10-10-2017, 06:13 PM   #7
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
There are a lot of mid entry level coil overs at the $1.5k range.
Tein Flex A and Tein Mono Sport come to mind. The Flex A is more street oriented while the Mono Sport is more track oriented. CSG is also developing a performance Flex A variant. RCE Tarmac 0/KW Variant 1/Variant 2 are also popular and have good value.
It's hard to get a sense of how low you actually want to go without a reference, but I think most of the performance coilovers have lowering potential that should suit most people's needs. If you get performance coil-overs, there are usually recommended ride height adjustment specifications. If you deviate from the specifications, you'll have to dip into preload/shock travel (which is not ideal). This enables more ride height lowering at the cost of performance potential.
I DD my Flex A and have been pretty happy. I think they have tremendous value and perform well. Front camber plates standard was definitely appreciated
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
Clipdat (10-10-2017)
Old 10-10-2017, 06:42 PM   #8
strat61caster
strat61caster's Avatar
Eibach Pro-kit Springs + Koni Yellow or Bilstein B6
Alternatively: Swift lowering springs, Racecomp lowering springs
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Teseo (10-10-2017), x808drifter (10-10-2017)
Old 10-10-2017, 06:44 PM   #9
Cchmelir
Drives: Subaru BRZ
Thanks for the replies, now I have somewhere to start looking.
Looking at the standard Tein flex A it says that the max low front 2.3" and rear 3" which is enough where I would be happy. I definitely don't want to start messing with the preload just to get lower. How much of a difference is their in performance between standard Tein flex A, the CSG version, and the mono flex option?
Old 10-10-2017, 06:58 PM   #10
imnotsureaboutbrz
Drives: between cars...
I'm interested in hearing more about this too.... @CSG Mike
imnotsureaboutbrz is offline   Reply With Quote
Old 10-10-2017, 07:03 PM   #11
Old 10-10-2017, 07:05 PM   #12
The internals have been completely reworked to transform the Flex A from a generic coilover to one fully customized to suit the FRS/BRZ/86 platform. The damping forces have been altered to synergize with the chassis, and the unused range of adjustment eliminated.
That says it better than I can.
imnotsureaboutbrz (10-10-2017)
Old 10-10-2017, 07:07 PM   #13
imnotsureaboutbrz
boy o boy next season is gonna be fun! (and expensive)
Old 10-10-2017, 07:09 PM   #14
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
My Flex A's worked well on the street. The hyd bump stop really helped smooth out the ride.
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
CSG Mike (10-10-2017)
coilovers, suspension
Need help picking coilovers Cchmelir Brakes, Suspension, Chassis 5 10-11-2017 02:33 PM
Picking up a 86, or maybe not... andyzpandy Scion FR-S / Toyota 86 GT86 General Forum 24 05-12-2015 05:04 AM
A little help picking a set up.... wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 11-18-2014 07:41 PM
Picking her up at 5! remorse87 Scion FR-S / Toyota 86 GT86 General Forum 14 10-07-2012 11:51 AM
