Old 01-13-2018, 07:09 PM   #57
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by new2subaru View Post
Wheel and tire sizes?
Motegi Forged Traklite 1, 16x7 +40, 225/50-16 (currently RT615K+)
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
new2subaru (01-13-2018)
Old 01-13-2018, 08:16 PM   #58
new2subaru
Weight Weenie
Drives: 15 FR-S
What do you think of the 16's? I'm thinking a little more sidewall would be nice for a DD
Old 01-13-2018, 09:03 PM   #59
venturaII
venturaII's Avatar
I love 'em. Better ride quality, noticeably lighter weight, and still better grip. Plus I think the fat tire look of this combo looks good on the car, and the brakes fill the space inside the wheel better. The amount of sidewall a 215/45 offers is kind of ridiculous for a street driven car, especially up here in the northeast. Everyone moans and complains that going to a 50 series tire will 'compromise response' and 'dull handling', but the reality is that the tire make and model is 90% of what you're feeling regarding responsiveness - not the minuscule difference between a 45 and 50 series tire. The argument is additionally made by some that a 225 is too big for a 7" rim, but again, not the case with this combo...check out TireRack's sizing and you'll see a 7" rim is right down the middle for a 225/50, and is what they use as a base for all their measurements. And if you're still convinced you're giving up the nth degree of response, just add another few pounds of air to your tires. Never mind that there are dozens of rubber bushings in the chassis also contributing to this response 'problem'.
The Following 3 Users Say Thank You to venturaII For This Useful Post:
Cole (01-15-2018), new2subaru (01-14-2018), why? (01-14-2018)
Old 01-14-2018, 02:25 AM   #60
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I have 16x7 rims too and I was considering the tire dimension (205/55 vs. 225/50). Truth is that TireRack and tire manufacturers suggest a 225 size on a 7" rim. Nevertheless, I've seen pictures of this combination and I don't like it. Especially on particular tires I was considering. I think that this size is based on some general "rule" mainly for ordinary cars and there was never a differentiation for sports oriented cars. Besides, the 205 tire is lighter and given that the grip difference is very small it seems to me a better option.
The Following User Says Thank You to nikitopo For This Useful Post:
why? (01-14-2018)
Old 01-14-2018, 05:12 AM   #61
new2subaru
Weight Weenie
Drives: 15 FR-S
Thanks man! I really appreciate the feedback.
The Following User Says Thank You to new2subaru For This Useful Post:
venturaII (01-14-2018)
Old 01-14-2018, 05:22 PM   #62
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
I think 205 is better on a 16, that's what I have.
The Following User Says Thank You to why? For This Useful Post:
nikitopo (01-14-2018)
Old 01-14-2018, 06:27 PM   #63
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
ventura: is there a pic of your car on the board somewhere? This strikes as an interesting possibility. Thanks
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 01-14-2018, 06:31 PM   #64
venturaII
venturaII's Avatar
I'll take the extra pound or so penalty for for an extra 3/4+" of rubber on the ground, not to mention significantly more tire options to choose from in the autocross/trackable rubber category.
Old 01-14-2018, 06:33 PM   #65
venturaII
venturaII's Avatar
Yeah, I think I posted one in the 16" rubber thread at one point. I'm no pro photographer though, and I have a simple flip phone, so any photo you find is going to be pretty low qual.
Old 01-14-2018, 06:42 PM   #66
why?
why?'s Avatar
Drives: series.blue
if that is what you are using it for then sure, but if it is a dd like mine I want the lightest wheels and the lightest tires I can find. I wish there was lightweight 16x6.5 wheels for our cars, but their just is not.
Old 01-14-2018, 06:52 PM   #67
venturaII
venturaII's Avatar
I dd mine as well. I use 205/55 on 6.5 steels for winter only. The rest of the year I use 225/50; I have a set of early spring/late fall tires (in the 340tw range)for cool weather, and a set of sticky tires (180-200tw) for warm weather/track/hooning.
Old 01-14-2018, 08:01 PM   #68
fatoni
why?
Drive upgrades. Don't buy them.
Old 01-15-2018, 01:59 AM   #69
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I measured once a 205 tire on a 6.5" rim and another on a 7" rim. The rubber on the ground is more with the bigger rim. The 225 tire will give a bit more rubber, but less than 3/4+".
Old 01-15-2018, 04:32 AM   #70
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
https://blog.caranddriver.com/tested...-fiber-wheels/
~24% reduction in wheel/tire weight + a ~4% gearing reduction leads to ~8% in-gear performance difference that decreases as speed increases.
As for coast down from 60mph, a ~3% difference. Considering that the gearing change means the high-revving Mustang is more in its power band and gets a gearing advantage, I'd say the coast down is a better measure of wheel weight's impact.
The GT350R weighed 3710lbs. The GT350 wheels weight a total of 58 lbs more. That's ~1.6%. Keep in mind that I rounded all my other percentages. Anyway, if you're getting ~3% difference in inertia after dropping ~1.6 per cent in curb weight, that suggests about a 2:1 ratio weight loss improvement from wheel weight versus other weight. Then again, the weight of those GT350R tires is ~4% inwards versus the GT350 tires. That also reduces the inertia. Maybe 2:1 is generous?
So ~$16,000 to reduce tire/wheel weight by ~15lbs/corner (about 24%) yields a significant difference but nothing to blow your mind.
What I suggest you all do is get some 215/35R17 Yokohama S-Drive tires on stock rims. They'll make the car feel much faster. You get a free lowering, too.
Also see this: http://hpwizard.com/rotational-inertia.html
He suggests 2:1 at most. That jives with what I'm seeing with C/D's article.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
churchx (01-15-2018), nikitopo (01-15-2018)
Will changing wheel width and offset affect alignment? azynneo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-15-2017 02:46 PM
Am I missing something (fuel consumption vs performance vs weight) GRoss FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 33 09-23-2014 04:34 PM
Ideal size width and weight for max performance Boofneenee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-29-2013 04:44 PM
Best light weight performance tire brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 12-04-2012 03:24 PM
