#15 |
Drives: Subaru BRZ Limited
| The Following User Says Thank You to JoeC For This Useful Post: | strat61caster (09-29-2017) |
#16 |
Drives: 15 BRZ LTD, 05 FXT
So my personal preference is to use a dedicated set of track pads and rotors, and dedicated set of street pads and rotors. It's easy to swap on these cars, and keeps compound transfer nice without lots of extra bedding. This method has a TON of benefits if you're willing to swap the pads and rotors before you go out each time.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#17 | |
idk I've never bothered to swap rotors and I've had 3 different pads on my car, it'll be 4x if the rotors last long enough and I burn through my current DD pads and put autox pads on, I know many shops/amateur racers don't bother either like CSG. 63k miles and counting so I'm not losing a huge amount of life by tracking XP10's, but I don't burn through a set of pads in 4x track days like the fast drivers do. |
#18 |
Drives: NSX, G35, E36 328i racecar
As others have stated, those rotors are fine, though it's always worth checking thickness when you have access. The discard thickness for those rotors is 22mm. Cracks will be visible on the inner and/or outer diameters of the rotors and will appear dark.
| The Following User Says Thank You to SpartaEvolution For This Useful Post: | JoeC (09-29-2017) |
#19 | |
Most important imo, is you have dedicated sets where if you totally smoke something, if a caliper locks up and ruins a pad/rotor, you can get your car AAA'd home, swap your stock stuff back on, and not freak out about how you're going to get to work Monday morning. I think these are the sort of advantages that are beneficial for the good driver who can really work brakes, but isn't at the track every weekend. If you're there all the time, it makes sense to just run one setup all the time. Also, they aren't necessarily advantages for everyone. For me one of the biggest advantages is knowing if something goes wrong and you total smoke the brakes, you can still get to work on Monday and not worry. I'm also the guy who has winter tires, all season tires, and autox tires for my Forester XT so I have a seasonal transition tire. Over prepared as heck, but it does have it's benefits.
| The Following 3 Users Say Thank You to JazzleSAURUS For This Useful Post: |
| DIY: Front Brake Pad and Brake Rotor Replacement | F1point4 | DIY (Do-It-Yourself) Guides | 28 | 03-21-2021 10:22 PM |
| Brake rotor temperature right/left and front/rear comparison questions | HappyMonkey | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 79 | 07-07-2017 03:29 PM |
| Alcon Front Brake Kit, 4-piston 332x28mm Rotor Size - now available!! | FRSport.com | Brakes, Suspension, Chassis | 0 | 07-08-2016 08:14 PM |
| Brake Pads + Rotor | Mikeez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 10-01-2015 10:34 AM |
