#57 | |
Drives: BR86
![]() Back to OP - I'm keen to hear of the gritty little details of engine failure. |
| The Following User Says Thank You to ZZT86 For This Useful Post: | strat61caster (09-12-2017) |
#58 | |
By the way your gripes for this car sound like absolutely nothing is wrong. Welcome to 86 ownership.
| The Following User Says Thank You to strat61caster For This Useful Post: | ZZT86 (09-12-2017) |
#59 |
Persona Non Grata
Drives: '15 BRZ (WRB)
They're not bugs, they're features.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | strat61caster (09-12-2017) |
#60 | |
Drives: Toyota GT86 Coupe Red (UK)
I wonder why you guys get a shorter schedule? Fuel quality? Road condition? Climate? Profit? Marketability?
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
#61 |
Huge E85 fan!
Drives: 2016 Scion FRS
It might be climate- much of the US gets over 100 F in the summer. It might also be the stricter environmental regs in the UK. Part of the impetus to push out the OCI is so that there's less used motor oil in the waste stream- the stuff is a toxic waste.
#62 |
Drives: 2013 Rally Blue BRZ
I have an early '13 that spun a rod bearing around ~53k miles. I'm at 60k now, a bit terrified it'll happen again but they covered a new block under warranty.
Were you unable to prove your service records? I had a hard time with that but eventually cobbled enough together where the regional Subaru guy approved the work. |
#63 |
Unusually a spun bearing is caused buy lack of oil in a engine with 20k on the clock, that said with only one qt. left wouldn't a low pressure light have come on?
On a different note. I did have a high performance engine spin a bearing just last month but I am sure that 500 hp. in a 3 lt. track car had nothing to do with its demise. Wait, can I go after ford because they made the block? What was interesting was it happened at the shop when the engine was cold the next week. It went tic tic tic clank at idle. |
#64 |
Drives: 2013 WRB BRZ
Looks like I'm in a similar boat. Pulled over immediately and checked the oil which was still perfect since I had just changed it 150 miles previous.
#65 |
Drives: 2005 Toyota Camry
#66 |
Persona Non Grata
The low oil level will play havoc with the oil temps. The oil will get severely hot, the viscosity drop to 0 and stuff starts to seize up even if the light stays off. Just because it has SOME oil in it isn't good enough.
Lights are really good at telling you you just binned an engine.
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | strat61caster (09-22-2017) |
#67 | |
| The Following 2 Users Say Thank You to Shibby For This Useful Post: | Capt Spaulding (09-23-2017), strat61caster (09-22-2017) |
#68 | |
Drives: 2016 ZC6
My build thread: Pointmutation's WRB BRZ build
#69 |
Sorry to necro this thread but I finally got my car into the dealership and they agreed to replace the short block. Too much sealant blocking oil passage for cylinder 4 so clearly not my fault. Didn't even have to call SOA or argue, all I did was provide proof of oil changes every 3300 miles and showed them my milky way galaxy that came out of the oil filter. Really happy with Subaru.
#70 | |
Drives: 2013 Scion FR-S Series 10
| Toyota drivetrain warranty denied - suggestions? | jamison884 | Issues | Warranty | Recalls / TSB | 19 | 10-11-2017 07:42 PM |
| PT warranty might be denied because of previous owner | Terruko | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 08-03-2017 09:27 PM |
| Has anyone had a warranty claim denied? Seized engine! Pics of teardown added 6/5 | CSG Mike | Issues | Warranty | Recalls / TSB | 909 | 09-15-2016 11:31 AM |
| Catalytic converter warranty denial by Subaru. 100% Stock engine! | CSG Mike | Issues | Warranty | Recalls / TSB | 152 | 09-03-2013 03:31 PM |
| Anyone leave engine stock but mod the heck out of the cosmetics to save warranty? | BlackyRose | Issues | Warranty | Recalls / TSB | 35 | 08-26-2013 07:45 PM |
